More powerful starter installed
Old Jan 12, 2005 | 08:45 AM
95bluse's Avatar
Hey guys just wanted to let you know that my starter finally died last weekend. The symptoms before were intermittent slow cranks, just barely turning over the engine, before it started. Finally all it did was click as i turned the ignition. I bypassed the solenoid by shorting the terminals, nothing from the starter so I knew it was dead. Anyway, went to my mechanic with the old starter and we visited a rebuild shop he uses for starters/alternators. The owner told us to get a new starter as opposed to a rebuild, since the new ones were more powerful and really turns over the engine snappily. He said it was redisigned by Nissan because the original was underpowered and caused it to burn out due to the fact it wouldn't crank fast enough to start the car, causing the starter to overheat.He showed us his book with the specs as I was skeptical it would fit work in my '95 (I've had one starter that wouldn't fit properly from another shop a few years ago). The drive gear on the starter was 10-tooth and length-wise was quite shorter, and the body of the starter seemed slightly longer.
To get to the point finally , I installed it and all I can say is it a HUGE difference! The car kicks over instantly, just turn the key to start and release immediately. I don't think this car has ever started like this even when i got it in '97. Agreed the starter is brand new & my battery is just over a year old, but I have to say that the car has never ever kicked over like this.
The bad news is that I forgot to ask him for the part# to pass on. I will try to get that if anyone here is interested. BTW I'm in Toronto and I got it at cost for $120CAD. Was only $30 more than a rebuilt.
Hope this helps!
Old Jan 12, 2005 | 09:23 AM
craig10114's Avatar
got the same starter from Jeff at Max Tuning.....the differnce is amazing. BTW the real differnce is that the internals from the new starter are out of the 5th generation and 6th gens. and the casing is from a 4th gen. It is from nissan design but i dont know if the ones u or i got are OEM or just OEM replica
Old Jan 12, 2005 | 09:45 AM
95bluse's Avatar
I agree, the guy at the shop did tell me it works on 2000 Maxes. He also said that he sells them to guys that build high-compression race engines Whatever it is, looks like it a darn good starter.
Old Jan 12, 2005 | 10:17 AM
RockfordMax's Avatar
Back from the dead
please try to get the part #! my starter is about a month away from dying, ive done so much to try to save it, but on most days, 3-4 seconds of cranking to start... its embarassing in a parking lot.
Old Jan 12, 2005 | 11:06 AM
One Crazy Max's Avatar
i want a new starter. i hate the wait and the sound the stock starter makes..
Old Jan 12, 2005 | 12:24 PM
Back from the dead
exactly what i was trying to say thank you crazy
Old Jan 12, 2005 | 12:41 PM
DAVE Sz's Avatar
Hooooooonda.....
More powerful starter? Ok, he's probably talking about the one with the 10-tooth gears as opposed to the old 8-tooth one.
Old Jan 12, 2005 | 12:49 PM
vortechpower's Avatar
Find out the part #!
Old Jan 12, 2005 | 12:59 PM
95bluse's Avatar
That's the one, though I believe that there has been internal changes also ( windings/stator etc) making it more 'powerful" so to speak.
I'll see if I can get the part number from the shop.
Old Jan 12, 2005 | 01:08 PM
95bluse's Avatar
Just spoke to the shop, and they said it's imported from the US, but won't give out a part #. I guess they are trying to protect their business since they normally sell to mechanics only. The only thing they mentioned is that it's the new "high-torque" starter for the max.
Sorry guys...maybe a google search will turn up something for you guys in the US?
Old Jan 12, 2005 | 01:09 PM
DAVE Sz's Avatar
Hooooooonda.....
The 8 tooth one isn't made anymore as it was replced with the 10 tooth. Go to nissan dealer and you'll get he 10 tooth one or jusk ask for the part number.
Old Jan 12, 2005 | 01:23 PM
95bluse's Avatar
I wasn't aware of 10 vs 8-tooth issue because I've always used rebuilt starters, so Davesz is most likely correct. I did a quick search and this link:
http://verizonsupersite.com/4alterst...rtcom/starters
Old Jan 12, 2005 | 01:26 PM
MAXRB8's Avatar
So let me get this straight, if we pickup a 10 tooth from where ever we've got the right starter? Or is there more to it than that?
Old Jan 12, 2005 | 01:29 PM
DAVE Sz's Avatar
Hooooooonda.....
That's it, nothing more to it. As I said before I'm always right, most of the time.
Old Jan 12, 2005 | 02:21 PM
MAXRB8's Avatar
"Most of the time" doesn't that make you wrong one more time?
and isn't it 10 teeth as in plural? Not 10 tooth!
oops wrong again!
but hey all kidding a side thanks for the tip, I'll definitely make sure I get a 10 tooth/teeth ( whatever) when my starter dies!
Old Jan 12, 2005 | 02:40 PM
DAVE Sz's Avatar
Hooooooonda.....
10 teeth doesn't sound right in that instance. A 10-tooth design sounds fine, 10-teeth design doesn't.
Old Jan 12, 2005 | 03:22 PM
Back from the dead
hmm i like dem dere 10 teef starturs yay dey mak my ngin goh vroom fastuh
Old Jan 12, 2005 | 06:01 PM
Armelius's Avatar
Correctly it's ten teeth. You don't say, he lost his two front tooth.
Old Jan 12, 2005 | 06:40 PM
Broaner's Avatar
2060lbs and falling...
Any starter that works in a 4th gen will work in a 5.0 gen.
Old Jan 12, 2005 | 07:29 PM
95bluse's Avatar
I think that if you go to a dealer and buy a NEW starter, chances are you'll get the 10-teethed variety. However, if you go the rebuild route with a supplier of your choice, they'll give you the crappy-slow turning older one. But then again I've been known to be wrong ( albeit rarely)
Old Jan 12, 2005 | 07:36 PM
DAVE Sz's Avatar
Hooooooonda.....
No **** einstein, you're one of the smart ones aren't you? I doubt you would say a 10 teeth gear opposed to a 10 tooth gear. You'd say a gear with 10 teeth but that's common sense smarty. It just doesn't sound right. Either way, you're not helping so shut up.
Old Jan 12, 2005 | 08:38 PM
Armelius's Avatar
Chicago is cold now isn't it? brrrrr
Old Jan 12, 2005 | 08:41 PM
DAVE Sz's Avatar
Hooooooonda.....
? Yes, it is. Why? Wanna come by or something? Is that supposed to be a threat or do you like being Captain Obvious?
Old Jan 12, 2005 | 08:57 PM
Guttermouf5150's Avatar
why is this guy allowed to talk?
Old Jan 12, 2005 | 09:00 PM
DAVE Sz's Avatar
Hooooooonda.....
ANother one. What did I do now? I said something to you a few months ago and now you feel the need to chime in for no reason?
Old Jan 12, 2005 | 09:15 PM
chenzarino's Avatar
Dave is right it would be 10 tooth, whenever referencing a sprocket it is tooth, not teeth. Teeth are in your face.
Old Jan 13, 2005 | 05:34 AM
Armelius's Avatar
Lol.
Old Jan 13, 2005 | 05:46 AM
deezo's Avatar
I have 10 Tooths and 1 teeth.
I wish those starters weren't Lester or Hitachi. I think I'm going to try to find another, better brand.
Old Jan 13, 2005 | 07:02 AM
MAXRB8's Avatar
Bah! ha! ha!, Let's face it the English language has been hacked so badly anything goes, it's nothing to do with sprockets or the "teeth in your face", if you only had one you still don't have teeth in your face you have a tooth! Besides they're in your mouth!! It's a case on singular tooth and plural teeth, so anything with more than one should be teeth, but like many things in the english language what sounds right and what is are two different things, but hey we've learned that..... CORRECTLY PHRASED.... a starter with 10 teeth! is the starter of choice!! (not a starter with 10 tooth) it's all about the grammar!
Intensions are what it's about and thanks to Dave Sz knowledge we are all better off and thats what this forum is about, even though he does have a tendency to rub people the wrong way
Old Jan 13, 2005 | 07:15 AM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I have a used starter from a 2000 Max on my car. It has 25k or so miles and it starts up instantly and does not have abnormal noises. Best $20 I've ever spent. auto/5speed uses the same starter.
Old Jan 13, 2005 | 09:38 AM
FormorAccordMan's Avatar
Thats funny
Old Jan 13, 2005 | 10:41 AM
SDot82's Avatar
I almost died laughing when I read this.
Old Jan 15, 2005 | 11:43 AM
eturnl
Cant you pull the part number off the starter itself?!
Old Dec 13, 2006 | 03:43 PM
JwaxMax99's Avatar
Hope this helps!
I know what you mean. Today I put in the 11 tooth starter. WOW. Car never started this quickly!
Old Dec 13, 2006 | 07:33 PM
oVeRdOsE's Avatar
Sorry to broke this chain of english courses, but if I want a new starter, I just need to ask for a 10 teeth starter, thats it? And it will be a fast one, no matter what. All the 10 teeth are fast?
vingodine
45
May 21, 2016 12:46 PM
JRod28
Feb 4, 2016 11:07 AM
homewrecker
Aug 24, 2015 08:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
