rpm moves up and down at idle sometimes
Old Jan 12, 2005 | 02:48 PM
dss42's Avatar
my rpms keep moving at idle does it every few minutes or so.. Not a huge move just a little movement. What can be the problem?
Old Jan 12, 2005 | 03:37 PM
wariow's Avatar
no problem. RPM's goes up to charge your battery. Your fan probably went on and it needed a lil juice to the alternator to charge the battery.
Old Jan 13, 2005 | 04:37 PM
dss42's Avatar
but it goes up and down while i am listening to music acts like its going to stall and I hear the exhaust pushing the air out.
Old Jan 13, 2005 | 04:42 PM
konak85's Avatar
I had a similar problem after i adjusted my belt tensioner. I reset my ECU a couple times and it went away. Weird, but it worked
Old Jan 13, 2005 | 05:59 PM
caudio51's Avatar
might be the TPS sensor
Old Jan 13, 2005 | 06:21 PM
Bags's Avatar
VG Ridah's Biatch Hoe
seafoam and clean your TB
Old Jan 14, 2005 | 11:55 AM
dss42's Avatar
already changed that 3 months ago, problem went away alittle.
dss42's Avatar
seafoam?? TB cleaned 1 year ago thats when problem started.
I am thinking its the coil pack?
Old Jan 14, 2005 | 12:24 PM
Kehops's Avatar
You would have other symptoms like stuttering when accelerating if it were your coilpack. Clean your IACV, TB and Seafoam injectors.
Old Jan 14, 2005 | 12:27 PM
PTownMax's Avatar
I still miss the max
clean IAC valve, guarintee it will fix ur problem
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
