Need INFO: Maxima trunk conversion
My 96 has the pass-through...
And I have a GXE as well.
My friend has a 94 GXE and he didnt have a pass-through. When you pull down the armrest, the plastic piece that seals the cabin off from the trunk is actually a very stiff cardboard-like material.
We just took a utility knife and cut it out. Put some molding around the edges, it will look stock.
Good Luck.
Good Luck.
My 96 GXE auto with C/C package has that pass through. I kind of remember it is standard on all Maxima 95 to 99, right? Maybe the very basic GXE with no option deosn't? Or could be the previous owner modified it for some reason, if you are not the first owner?
jiaxima96: You are right. I guess I am the unfortunate one then. I have the GXE manual. Is there a way to modify it to have that trunk pass through?
Originally posted by jiaxima96
I found the 96 Maxima brochure. In the spec section there is an item "interior". In it, it says the trunck pass through is not available with GXE manual transmission. It is available with all the rest.
King_Ten_Ahead
Sep 30, 2015 04:27 PM
