Starter problem?
Old Apr 25, 2001 | 02:32 PM
ßaller's Avatar
I got a 1995 Max with 135k+ on it. This is what happens.
I'll start my car in the morning, lunch, and home it is fine. If I were to stop at a convenient store before work or whatever, and shut off the car, the car would not start. It'll take anywhere between 40mins to 1.5hrs before the car starts. Weird? You can hear a ticking sound but the car does not start, battery is fine all power window and cd works. I am guessing the starter, right? What brand at the local auto store should I be getting? Anybody had similar situations?
-ßaller
Old Apr 25, 2001 | 02:40 PM
Sonic's Avatar
The fact that the windows and CD player work don't mean that the battery is fine. Get your battery professionally tested before blaming the starter.
Old Apr 25, 2001 | 02:44 PM
ßaller's Avatar
Well, that is out of the question. I have a 3 month old Red Top Optima battery, so no I cannot and will not blame my battery.
Old Apr 25, 2001 | 02:54 PM
Sonic's Avatar
An alternator that doesn't charge the battery will kill your Red/Yellow Top, or any other battery.
Old Apr 25, 2001 | 03:44 PM
Daniel B. Martin's Avatar
Medicsonic is right. Don't condemn the starter without doing more diagnostic work. The starter is an expensive part and you don't want to replace it unless you are certain it is bad.
That being said, we should also remember that there have been many reports of starter failures on the '95 Maxima. Later starters had design changes which made them more durable. The later starters are compatible with the '95 engine.
Starter replacement is a job which can be done by the home mechanic.
No need to jack the car, the starter motor is accessed from above.
Remanufactured units are available for $140 (Brand X) up to $360 (Bosch).
If done by a professional the labor charge ought to be one hour.
Make written notes of the radio station presets. Disconnecting the battery will cause the radio and clock to experience "amnesia".
1. Disconnect the cable from the negative terminal of the battery.
2. Remove the air intake duct and the air cleaner housing assembly.
3. Disconnect the battery cable and the solenoid terminal connection from the starter solenoid.
4. Remove the two starter motor mounting bolts and remove the starter from the engine. These bolts may be really tight!
Installation of the starter is the reverse of steps 1-4, above.
Set the clock to the correct time. Refer to the notes made in step 1 to restore the radio station presets.
For more information (and photos) go to http://vbxmaxima.8m.com/starter.html
Old Apr 25, 2001 | 04:53 PM
Micah95GLE's Avatar
Don't forget to make a note of the time, too, before disconnecting the battery.
Old Apr 25, 2001 | 07:32 PM
dch95's Avatar
Saaaaaaaay what?!?!
Won,t this be useless an hour and 13 minutes later?
Old Apr 25, 2001 | 08:13 PM
Humor
It was a joke. You really were joking, weren't you Micah95GLE? Sure you were.
Old Apr 25, 2001 | 08:50 PM
Micah95GLE's Avatar
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
jwright36
Sep 8, 2015 11:45 AM
