Shock/Strut Advice?
Old Jan 16, 2005 | 04:23 PM
komodo693's Avatar
Shock/Strut Advice?
My OEM's are just about gone. Was wondering what were a good replacements for hard driving - I mean NYC daily commuting. Better handling while still maintaining the "soft" ride.
thanx in advance!
Old Jan 16, 2005 | 04:43 PM
Terran's Avatar
Do you want to lower or stick with stock springs?
Old Jan 16, 2005 | 04:50 PM
flthere's Avatar
Maybe Monroe sensatrac ?!? plz lemme know if sbdy got them on and how much for them to be installed ...
Old Jan 16, 2005 | 06:52 PM
blackmax_kid's Avatar
if you want better handling you'll have to sacrifice some comfort, vice versa but a good setup is tokico
Old Jan 16, 2005 | 11:19 PM
1996blackmax's Avatar
Here is a good link:
http://maxmods.dyndns.org/index.php?MaximaHandling
The page on shock is here:
http://maxmods.dyndns.org/index.php?MaximaShocks
Old Jan 17, 2005 | 01:23 PM
komodo693's Avatar
Thanks for the advice - been reading the info.
Keeping the stock springs - need to go over the potholes in NYC.
Also have to do the front wheel bearings
Old Jan 17, 2005 | 01:27 PM
dmBK's Avatar
How 'bout them cliffs?
get AGX gr-2. they're 15% stiffer than stock. i think u'll like it. also, a rear sway bar (addco or progress), and you should be good to go.
monroe is garbage.
Old Jan 17, 2005 | 01:37 PM
Terran's Avatar
If I was sticking with stock springs then I'd go with GR2's too.
You may also want to look into replacing your stock GXE springs with stock SE springs. They're a bit stiffer and a bit better handling, but retain stock ride height. You should be able to get a set real cheap if you post a WTB in the 4th gen classifieds forum. '95-'99 will all work.
Old Jan 17, 2005 | 04:04 PM
njmaxseltd's Avatar
KYB GR2's are a very firm strut. They will handle NYC streets quite well.
Tokico Blue performance struts will give you that nice new car ride back again. They should also handle NYC streets with ease at the stock ride height.
Old Jan 17, 2005 | 06:52 PM
L.I. I30t's Avatar
I have the KYB AGX and springs from Ebaich and the ride is very firm. I like this setup and it handles very well. The down side is that you will feel every bump in the road.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
