Anyone ever try to remove front sway bar end link?
Old Jan 17, 2005 | 02:11 PM
RichMax's Avatar
Boosted like Snipes tax refund
Mine is shot. It is a simple set of bushings and metal which ties the front sway bar to the front suspension. The only problem is, I can't get the old one off because it is designed to rotate, so I can't use a ratcheting wrench to get it off. Any ideas on how I can remove it if I can't get the lower half to stop spinning with every turn of the ratchet?
Old Jan 17, 2005 | 04:01 PM
njmaxseltd's Avatar
Are you trying to remove the whole link assembly off the control arm or just the bushings? The nut on top holds the bushings and should come off without the rod spinning. If you have to replace the entire link due to the ball joint failing then I believe you need a box wrench to turn it and an allen key to hold the center from rotating while you remove the assembly from the control arm.
Somebody correct me if I'm wrong.... I've never removed the entire assembly, just replaced the bushings, which is a very simple job.
Old Jan 17, 2005 | 04:29 PM
RichMax's Avatar
Thanks for your response. I don't see anywhere on the lower half of the upper end of the link (above the ball/joint but beneath the sway bar) where an allen wrench would fit or be used. Perhaps I am not sure enough about what an allen key is. It's a hexagonal tool with a right angle in it, right? (I Googled it)- So- where on earth would one go? I'm stumped
You're right, by the way- the ball and joint is missing, so the part of the link that is on the control arm is completely separate from the part still attached to the sway bar.
Old Jan 19, 2005 | 05:31 AM
RichMax's Avatar
bump to the top...
Old Jan 19, 2005 | 06:49 AM
twiggy144's Avatar
I replaced the sway bar end link 6 montha ago. I dont remember any allen key required to hold one end. I do remember cutting a nut with my dremel, because it was all rusted and seized.
Old Jan 19, 2005 | 10:46 AM
brock3j's Avatar
That was my solution too, but I used the recip saw to cut it off, I thought i broke mine loose, turns out I rounded the nut, so 2 mins with a saw and i was done. $25 for the whole thing at carquest and i was done.
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
