wheel camber question
Old Jan 17, 2005 | 08:44 PM
bullfrog's Avatar
I don't really understand this whole camber thing. I'm getting coilovers on the max here in a week or so, and I'm hearing that I'll need a camber kit to avoid tire wear problems. From what I can gather, lowering the car would probably introduce anywhere from 2-4 degrees of extra negative camber. All the camber kits on maxmods.dyndns.org only go up to 2 degrees of correction though.
Are our cars set at 0 degrees camber initially? Is a 2 degree correction from a kit such as the Ingalls one going to be enough to fix practically any problems that could arise from slamming a car on coilovers?
I'm just pretty ignorant here, so pretty much any information you can provide me with would be excellent.
Old Jan 17, 2005 | 08:57 PM
005's Avatar
005
Also, if you place tokico struts and springs (the adjustable ones on customaxima.com going for $650) on your maxima, do you even need a camper kit?
Old Jan 18, 2005 | 05:24 AM
browne's Avatar
bump......
Old Jan 18, 2005 | 05:38 AM
mzmtg's Avatar
Minister of Silly Walks
The alignment specs are in the FAQ.
My car is lowered on H&R springs and my camber is right in spec at -1.0 degrees on both sides.
Old Jan 18, 2005 | 07:15 AM
bullfrog's Avatar
Okay, so I've read through the modification and 4th gen FAQs and there's still a couple things I'm not sure about. The factory spec is -1.0 degrees up front and -1.75 degrees in the back. Would it be enough to get a camber kit for the front only with a coilover setup, or would I need one for the rear too? How do I check the camber anyway? Can I do that effectively without taking it to a shop that does alignments?
Old Jan 18, 2005 | 07:44 AM
96ItaliaSE's Avatar
il massimi bassi
96 maxima has tein s springs on kyb agx 2.2" drop 2 finger gap
my alignment was 1.2 degrees driver front and 1.6 degress passenger front
I was in spec on the rear. A correction bolt ( which I ordered) with a +/- 1 degree should allow me to get in spec with no issues. If you off much more than I am youve got serious suspension issues. (balljoints, tierods etc)
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
