shave one of the stubs off?
Old Apr 25, 2001 | 08:32 PM
alloutmax's Avatar
i hear alot about shaving one of the stubs off on the clearance light, what does that mean
Old Apr 25, 2001 | 08:49 PM
Klamath
If you look at the clearance light, you'll notice that it has bumpy vertical lines. Those sound like they may be the stubs. I dunno if it would be that easy to shave them off, though. Sounds hard. Someone prolly knows for real
Old Apr 25, 2001 | 09:05 PM
teejnut's Avatar
i used a grinder... it was pretty easy took like 10 seconds... i did this rather then we wiring the corners to make them brighter
Old Apr 26, 2001 | 07:51 AM
JacksMax's Avatar
You never did mention what it was you used a grinder *on*.
This is about a 1157 LIGHT BULB. It has two elements, a bright one and a dim one. You can't put it in backwards because the way the little nubs on it are. One is higher than the other. You need to remove one to make them reversed, bright is dim and dim is bright.
The way you do it is to remove the higher one. Hold the bulb so that the glass is pointing up and the base is pointing down. See the two nubs? See the one thats higher up? You need to remove that one. Use a grinder, a file, a dremel would work great. Now put it back in the socket turned 1/2 turn from the old way. You should now have bright corner lights.
Also, read this thread:
http://216.122.219.59/forums/showthr...threadid=35386
Jack
Old Apr 26, 2001 | 07:56 AM
ILoveMyMax's Avatar
thnx for clearing that up Jake!!
Old Apr 26, 2001 | 09:46 AM
teejnut's Avatar
thanks for clearing up... forgot to mention what size bulb and stuff thanks
DBear
Sep 14, 2015 08:33 PM
rbaker100
Sep 6, 2015 02:46 PM
MaxStock
Aug 12, 2015 08:33 AM
1HOTMAX
May 24, 2001 06:26 AM
MaximaRacer
Nov 9, 2000 08:52 AM
