e-brake light intermittently on
Old Jan 19, 2005 | 09:44 PM
drues95se's Avatar
I am not sure if this is an easy fix or adjustment, but my emergency brake light goes on and off while I am driving, and most of the time it is on. I just need a little help to figure out what to do about it. Thanks
Old Jan 19, 2005 | 09:47 PM
acj's Avatar
acj
I believe you can pull up your cup holder and look at the switch. There should be some sort of switch under there that the ebrake comes into contact with. It may need adjusting so that it is being pushed in when the ebrake is down. Hopefully this makes sense...I'm not positive this is the way it works, but I think it is....
Old Jan 19, 2005 | 10:12 PM
Maxima99SE's Avatar
will fly for food
check brake fluid, sounds like it's low
Old Jan 19, 2005 | 11:02 PM
DAVE Sz's Avatar
Hooooooonda.....
e-brake light? didn't know we had one.
Old Jan 20, 2005 | 07:29 PM
Crockpot's Avatar
its just a red brake light, that comes on when the e-brake is activated
Old Jan 21, 2005 | 02:08 PM
drues95se's Avatar
thanks for the help, I'll have to check everything out and figure out what it is
Old Jan 21, 2005 | 03:22 PM
Ant96GLE's Avatar
Low brake fluid, dont bother taking apart your dash. Your brake pads are getting low.
Old Jan 21, 2005 | 03:33 PM
VIP Maxima
brake pad or fluid is low...
Old Jan 21, 2005 | 08:17 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
cable may be loose. check rear end.
Smackasmith
Feb 1, 2016 12:40 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
