aligment after lowering
Old Apr 26, 2001 | 02:47 PM
MaxPower's Avatar
I got some H&R springs and some Tokiko shock/struts installed a couple of days ago. Does anyone know if an aligment is needed??? Driving around my aligment seems fine, but I have read that people go back in a couple of month to get an aligment after they lowered there Maxima.
I don't want to pay for an aligment if I don't need one...
Old Apr 26, 2001 | 02:53 PM
Jeff92se's Avatar
I'm needing a caw
Do a search on alignment. But yes you should get it aligned after any suspension work.
Old Apr 26, 2001 | 03:09 PM
Ravq's Avatar
You can ride around without one but it'll cost you in the long run. Your tires will wear unevenly very quickly.
Old Apr 26, 2001 | 04:43 PM
Supa Lao's Avatar
When is the best time to get it aligned? Should I wait a few days to get it, so it can settle, or should I get it done the same day?
Old Apr 26, 2001 | 04:50 PM
Jeff92se's Avatar
I'm needing a caw
About a week is plenty.
Old Apr 26, 2001 | 05:34 PM
Maxima48177's Avatar
I would wait for about 2 weeks and then get an alignment. That way it gives your car time to settle and 2 weeks of bad alignment shouldn't harm your tires much. Don't assume that just because your car drives fine and that your steering is straight that you don't need an alignment. When lowering your car,it definitely affects the camber of your alignment and maybe other areas as well. You can only tell if your camber is off when you get an alignment or when your tires wear out. Save your money by just getting front aligned, the rear is not affected and you couldn't do any changes to it. Hope this helps.
Old Apr 26, 2001 | 06:44 PM
plrod Black 95 SE's Avatar
two weeks is about right, but definitly get an alignment, mine looked and rode fine after the drop but whey I got it aligned it was off a little; a decent shop should be able to align an H&R drop to within factory specs on a 4th gen w/o any camber kits.
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
