headunit wiring help, installed hu windows not working
hey guys im new here but i had a few problems with my head unit and trying to install it i tried wiring it up before i got the adapter and i saw two wires touch and it sparked and now my driver window works but all the other ones arent getting power and my new hu wont come on i was just trying to see if anyone had this same problem before and new how to fix it if it was a fuse or something thanks. erik
You should probably check the fuses first...that's probably the easiest thing to check. If you have a test light it will take no time...if not you'll have to pull them out.
After you do this, we can go from there if the problem isn't found...
If it keeps blowing fuses you need to check the wiring you did. Something isn't right or it wouldn't blow a fuse. The wire that "sparked" in the first place could be the cause of the problem. Check it and put it where it needs to go.
I have blown that same fuse and has a heck of a time finding it. Top fuse on the right most column. However I only blew it when craking my system really really loud. I don't think it should blow under normal circumstances. I replaced it with a 10A fuse just because I ran out of 7.5s and have not had a problem since. I have been meaning to change it back, just because I don't know if I might end up doing some serious damage, but just haven't gotten around to it. Anways, just fyi, I have blown the fuse just not that easily.
jerrod99_se-l
08-27-2015 08:27 PM
Viralkill
08-17-2015 10:54 AM
