looking for constant 12v source
Old Jan 24, 2005 | 03:46 PM
hollaatchaboi's Avatar
what is another constant 12 volt source other than the ciggarette lighter? How many things can i wire to the cigg lighter wire if i change the fuse?
Old Jan 24, 2005 | 03:51 PM
RA030726's Avatar
I'm nutty for Nissans
what ever the amp rating is....thats how much crap you can connect to it. DO NOT USE A HIGHER AMP RATING.
If in doubt use some of the extra ones in the fuse box.
Old Jan 24, 2005 | 03:55 PM
not sure wat ur talking about
Old Jan 24, 2005 | 04:05 PM
MDeezy's Avatar
the amp rating on the fuse is what I belive he means, if its a 7.5amp fuse dont go over that.
I remember reading a thread of someone who put a 15amp in for the cig and wired a microvison screen + p2 to it, had no probs. But I dont know about that stuff
Old Jan 24, 2005 | 04:29 PM
99se5spd's Avatar
if you pull too much current (amps) through a wire not meant to handle it you can melt the wire...and the whole car. go to the ignition switch, you can get as much as you want from there, just make sure you fuse it between where you tapped it and the component your hooking up.
Old Jan 24, 2005 | 04:45 PM
MDeezy's Avatar
how would one go about doing that? not too electrically inclined
Old Jan 24, 2005 | 04:54 PM
2 Da Max's Avatar
neways, just attac the remote wire on the audio fuse and your good.
Old Jan 24, 2005 | 06:21 PM
Terran's Avatar
The cig lighter is not constant. It's on when the key is at acc. or on. I have a number of things I want to hardwire in, so I think I'm going to use a relay with the cig lighter as the switch. Don't forget to fuse the things you hardwire if you use this method.
Old Jan 24, 2005 | 07:15 PM
RA030726's Avatar
if you look in the fuse box there are many open (unused circuits) that you can use. there are a few different methods to tap the power with,
I dont like these b/c they spread the contacts in the box and can cause fauly connections
these are better
I like these, but if you blow the fuse you need another one, I used to make these by hand, so they were free.
If you want you can go to the ignition harness and carefully remove some insulation and spread the wire apart (in half). Then insert the new wire into the hole, wrap the new wire around the old and tape securely. If you want to add a fuse block so you can install more circuits as necessary.
Old Jan 24, 2005 | 07:34 PM
2 Da Max's Avatar
uhm or you could just wrap the wire around the fuse??
Old Jan 24, 2005 | 09:55 PM
all the things in the fuse box are on only when the car is on or acc correct? I have some neons wired to the remote wire of my radio. However, sometimes the neons constantly fade and start to blink. So i figure I need a new power source. Right now, I have a 7" monitor, a fm modulator, and a switch for fog lights wired to the ciggarette lighter. I need to get power for a relay for a power inverter and i want to find a new power source for the neons. (If anyone may know why they blink..let me know. May it be because i have subs?)
Old Jan 25, 2005 | 02:23 PM
RA030726's Avatar
all the circuits in the fuse box are labled, ACC, IGN, BAT ..... so they are easy to determine. Hooking lights and what not to the amp remote turn on is
Old Jan 25, 2005 | 03:13 PM
99se5spd's Avatar
the remote wire for the radio is just a signal wire, and if your neons are fading than you are putting way too much stress on that circuit...you should never use a signal wire to power anything. go to the ignition harness like i stated earlier, remove the knee plate under the steering column and look for a harness that comes off the back of the ignition switch (where you put the key in) here are the wire colors...this is for a '99 no im not sure if they are the same.
constant 12v-white w/ red stripe and white w/ purple
ignition (the second "click" when the key is turned on, anything that is not audio or video should be connected to this)
-black w/ white or black w/ red
ACC. - red w/ yellow or red
the two wires for each one i listed is because they change colors at a plug so depending on what side of the plug you are on depends on the color of the wire. to tap the power get this:
there should be some at your local auto store, they are called t-taps, make sure you get the yellow ones (for larger wires) and crimp them on the wire anywhere using slip joint pliers, make sure the little latch clips, you can usually hear it when it locks together. than you can use a standard male connector to plug it into the t-tap, add a fuse and than you have power for whatever you are going to connect, you can safely run about 20-30 amps from here with no problem, anything larger than that (amp, foglights etc.) go straight to the battery. hope this helps you out.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Nov 15, 2020 11:52 AM
msellas
Sep 23, 2015 09:16 PM
lrb6805
Sep 17, 2015 04:49 PM
