tokico
Old Jan 26, 2005 | 01:57 PM
S103100F's Avatar
tokico
some one plz take pictures of your tokico top mountings of front shocks
Old Jan 26, 2005 | 03:16 PM
MAXRB8's Avatar
I just installed mine this weekend I don't have any top specific pics, but maybe I can help whats your question?
Here's a link to pics I do have:http://www.cardomain.com/memberpage/560141/3
Old Jan 27, 2005 | 10:12 AM
S103100F's Avatar
my thing is after my mechanic put them together one side is sticking out more than other side is it normal i'll have pics tomorow i 4got my camera today unles i'll take a pic with my phone lol
Old Jan 27, 2005 | 10:52 AM
TonyGotSkilz's Avatar
Mine did the same thing my mechanic (myself ) put it together exactly how he was supposed to (torqued to spec and all) and thats just how they came out. My passengers side is higher about half an inch then my drivers, but its not causing any problems so i believe its normal especially if ur's is the same. Maybe it has to do with an adjustment by tokico for the car being slightly heavier on one side (taking a shot in the dark) but as long as u don't have any negative symptoms (like me) your fine.
Old Jan 27, 2005 | 11:05 AM
MAXRB8's Avatar
The only thing I can think of is did you put the bottom end tip of the spring sitting in the "notched" lowest section of the strut mount?
In the above image on the right side of the Illumina where the spring would sit you can see a notched indented section, the end tip at the bottom of the spring should be sitting in there at the lowest point, if you didn't do that one end could site higher than the other, mine is totally level, you might get lucky and it may seat itself but I doubt it. Hope this helps and good luck
Old Jan 27, 2005 | 01:37 PM
gtr_rider's Avatar
192.168.1.1
The front struts have a specific side, not sure if that would cause that..
Old Jan 27, 2005 | 02:01 PM
njmaxseltd's Avatar
A worn strut mount could cause the threaded top part of the piston shaft to stick up further then it's supposed to.
Peter Paul
Jan 2, 2016 05:18 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
95Maxi
35
Sep 2, 2015 10:37 AM
