Headlight harnesses burning out
Old Jan 26, 2005 | 08:04 PM
nismos14's Avatar
§è~® f®ÈÄk
Just wondering why the harnesses burn out, is it just solely due to the heat? or is it something more?
Say for instance just changing the bulbs from 55w to 110w, would that be the cause of the harness burning? or is there more to it?
if i were to run two seperate housings with their own wires from the main headlight wire harness split to two seperate 55w bulbs, would the original harness then, NOT burn out?
thanks it all makes sense in my head just dont know why i can't figure out the answer on my own
Old Jan 26, 2005 | 08:17 PM
G4nismo's Avatar
oh yeah. i got aftermarket bulbs and they burned out pretty soon. just get some cheap durable aftermarket sockets. cut the old ones and connect the new ones.
Old Jan 26, 2005 | 08:31 PM
Nismotic's Avatar
Always sunny in philly
the higher wattage bulb is whats causing the burnout. The OEM harnesses can't withstand the wattage, therefore forcing you to pull over and jiggle with it until the headlight comes back on.
southwestautoworks sells the nokya upgraded wiring harness. I suggest you use that.
Old Jan 26, 2005 | 11:19 PM
Maxima99SE's Avatar
will fly for food
buy an upgraded harness or go HID
Old Jan 26, 2005 | 11:52 PM
ThurzNite's Avatar
I guess people are having success w/the nokya harness sold by swa. I had one, and didn't seem much better than stock. Anybody ever melt a Nokya?
Jae
Old Jan 27, 2005 | 01:36 AM
AllMaxxedOut's Avatar
I was having that problem also w/ the burning out of bulbs. Just found bulbs w/ wattage that the harnesses could handle. But I'm going HID in a month or so.
Old Jan 27, 2005 | 04:20 AM
Big Tyme's Avatar
Nokya harnesses don't look like the high end high watt harnesses, you know with the ground and everything, but they work pretty good I've had mine for about a year with MTEC 80/110 bulbs and have had no troubles yet. You can't beat the price. Oh yeah, I don't use my high beams ever with these bulbs that could be another reason the harness has lasted so long.
Old Jan 27, 2005 | 06:27 AM
nismos14's Avatar
§è~® f®ÈÄk
thanks, the reason i asked is because of something else that im doing, as long as it's the high wattage/heat that causes the burn and not the total amount of wattage going through the wires im good to go.
oh and still, no one answered this question....
Old Jan 27, 2005 | 10:47 AM
nismos14's Avatar
§è~® f®ÈÄk
bump still curious about this and would like to know other opinions
mclasser
22
Nov 12, 2020 01:58 PM
doctorpullit
Oct 28, 2019 10:58 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
