Plate frame
Old Jan 27, 2005 | 09:27 PM
JSniper0's Avatar
Plate frame
Theres only one problem with the body of my max. when i first got it, when i was switching plates on the rear bumper i noticed the two bottom screws were only holding the plate on. when i take the 2 bottom ones off i see that someone actually tore the 2 top holes off. (almost like there were bolts there before and they couldnt get em off so they tore the corners) so there isnt any holes up top its just torn. anyways, i want to get a frame for the plate but with my situation the plate and the frame will be tilted out. and i dont know if it will look good/right that way. any suggestions?? thanks -Jeff
Old Jan 28, 2005 | 04:33 PM
joeeey's Avatar
You can use a lager washer and a speed clip with a bolt. So when you tighten the bolt it will pinch the plate between the washer and the small left over piece of the bumper. Or screw the plate with self tapping screws then use a plate frame to cover the screws.
REDinLV
Aug 15, 2024 12:30 AM
knight_yyz
Nov 1, 2015 01:34 PM
