bose problem
Old Jan 29, 2005 | 09:31 AM
bobsbarricades's Avatar
bose problem
Ok, so I bought a used car with a bose sound system in it. It had one of those sony xplode heads in it and bose speakers. A little odd... Well we find out aparently you can't run the bose speakers on the sony head without burning out the sony head because the bose speakers are powered and send some of that power back to the head.
Is there any way around this? how much would a replacement bose head be? I wanna call em up but I figured I could come here first. Thanks for the help.
Old Jan 29, 2005 | 09:39 AM
Nismo3112's Avatar
Custom User Title
I would replace the Sony with a stock Bose unit. They can be pricy.. I sold my Bose HU for $192 on eBay
Old Jan 29, 2005 | 09:45 AM
do you know of any good ways to test to make sure the speakers aren' hurt? I could probably sell the xplode to help get the bose unit, but it would suck if I got it, then found out the sony unit damaged the speakers. How would I know what unit to get?
are the bose....amazing speakers?
Old Jan 29, 2005 | 09:46 AM
Nismo3112's Avatar
Custom User Title
I have a 97 Bose HU in my car right now (sold my 95 Bose unit) with stock speakers and a Sony Xplod Sub. Got to say it sounds pretty amazing. Plus i'm not a fan of the look of aftermarket head units and stuff. I like to keep it looking stock
Old Jan 29, 2005 | 09:49 AM
so ur usin an xplode sub? what would you compare the sub performance to the bose?
Old Jan 29, 2005 | 09:57 AM
Nismo3112's Avatar
Custom User Title
Well I didnt want the full range coming out of just the factory speakers. That would limit how loud I could turn it up before it would start sounding like crap. With The Sub and the stock stereo, you can turn off the bass going to the speakers. It sounds so d@mn good. And my Sub is only about 150 watts rms.
Old Jan 29, 2005 | 09:59 AM
gsmith795's Avatar
my stock bose sound system in the 4th gen i just bought is better than the aftermarket system i put in my old 3rd gen. and it was a quality system too!!
Old Jan 29, 2005 | 10:09 AM
Nismo3112's Avatar
Custom User Title
Yeah, I dont know why everybody hates on the factory Bose systems. With the sub I get a perfect balance of bass, mids, and highs.
Old Jan 29, 2005 | 10:10 AM
wait, how do you turn off the bass going to the speakers, but still send it out to the sub? crossover?? If you can use a crossover that sends out singnal to all the speakers, wouldn't you be able to use that crossover with the sony HU?
Old Jan 29, 2005 | 10:12 AM
Nismo3112's Avatar
Custom User Title
^^^ On the front of the Bose there is a **** to adjust the bass. Adjust it almost all the way down so you cannot hear the bass coming from the speakers. Then on my amp there is a low range filter, so it only picks up the lows. BTW my sub signal comes from the same signal going to the rear speakers.
If you want to use the Sony headunit, you can bypass the bose amps. (there are 4 of them, one at each speaker.)
Old Jan 29, 2005 | 10:15 AM
so you ran wires coming off of the speakers in the rear, into your amp, that goes to your sub?? If thats the case, then how is your sub getting the lows that you cut out from the head unit?
Old Jan 29, 2005 | 10:20 AM
Nismo3112's Avatar
Custom User Title
^^ The signal coming from the radio stays all the same until something changes it. When you turn the **** to lower the bass on the Bose HU, it is only telling the 4 small bose amps to lower the lows on the speakers.. I spliced the rear speaker cables BEFORE the signal goes into the rear speakers. So my sub is receving a completely unaltered signal. I could be totally wrong, but that is my theory.
Old Jan 29, 2005 | 10:43 AM
I understand what your sayin now. It wouldn't work on normal speakers, but I guess since the bose speakers are powered that it would.
so any ideas on testing the speakers?
Old Jan 29, 2005 | 11:23 AM
z32drifter's Avatar
you can wire the sony to the bose speakers.... and bypass the amps.... I would use an amp to power the speakers........ here is the deal with Bose.... the factory speakers are .75ohm.... normal speakers are 4ohm..... the reduction in resistance lets the amp in the radio produce more power than it should and can cause it to fail.... kinda like putting 3" exhaust on a weedwacker... if you use a 1 or 2ohm stable amp you won't have a problem with burning out the amp or power supply.... and the stock speakers don't need much power... I am running mine with a 4x50watt and have it turned way down ...... the system in my 300ZX is running on a 4x25 and works fine also ....
Old Jan 29, 2005 | 11:27 AM
jackiss2888's Avatar
look on the stickies, there should be a BOSE thing and it tells you how to hook the BOSE speakers up to an aftermarket hu. It wont cause any harm to anything if its done properly. its all relatively easy to do. pretty much, it cut out the bose amp and poweres it through the hu.
Old Jan 30, 2005 | 06:44 PM
what about these??
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
how do I "Search" i can't find it. Or do I have to do it manually
Old Jan 31, 2005 | 06:06 AM
has anybody seen those before? I found the sticky that talked about some kind of adapter, but it wasn't that specific kind.
Old Jan 31, 2005 | 02:53 PM
i dont mean to bump so often, but I wanna find out if this will work or not so I can work on it this weekend. If I dont get it before then, Then i have to wait quite a while before Ill have time again to work on it.
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
slowlifer
Sep 8, 2015 05:53 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
