would you guys recommend the superflo model warpspeed y-pipe?
Old Jan 30, 2005 | 02:24 PM
Armani
I'm looking to buy either the regular y-pipe or the superflo from warpspeed (found here: http://cgi.ebay.com/ebaymotors/ws/eB...category=33631). I don't quite understand why they were able to eliminate the flex section from the superflo model.
They claim that "NEW SUPERFLO MODEL OUTFLOWS THEM ALL".
So, what are the pros and cons of the superflo? I know not many have it, so perhaps those that do would know. Thanks
Old Jan 30, 2005 | 02:37 PM
MDeezy's Avatar
I think its just a gimick to make us think that its a better pipe and will give more gains tha their other non-superflow pipes.
I want proof its better.
Old Jan 30, 2005 | 02:42 PM
Armani
Well, here's my reasoning:
I don't care if the superflo performs better than the regular. It's sufficient if it just performs the same. In that case, the superflo would be better, not because it "outflows" the other (because lets say it doesn't), but because it eliminates the flex section, which we all know yields most problems in y-pipes (example: bees in the can sound, ripping, etc).
Old Jan 30, 2005 | 02:49 PM
oTranscendental's Avatar
Forget about it, you can always replace a flex section if it goes bad, you could even add a peice of pipe instead of flex or you can wrap the flex if the noise bothers you.
Old Jan 30, 2005 | 02:50 PM
MDeezy's Avatar
I didnt notice the flex section is gone. I hope no new problems arise with this lac of flex section but seems promising. well if it will give a little bit mroe flow but eliminate most of the problem encountered after installing a Y-pipe w/flex then, sounds like a good deal.
If you get it let us know how it install, anyproblems, no bees in can sound?
so is that another gasket we'll need to have put on the car?
Old Jan 30, 2005 | 02:51 PM
PTownMax's Avatar
I still miss the max
all they did is get rid of the flex... i wouldn't bother
Old Jan 30, 2005 | 02:55 PM
MDeezy's Avatar
Originally Posted by warpspeed performance
THE Y PIPES FEATURE:
100% mandrel bent aluminized steel tubing
Dyno and flow tested design
Bolts up to stock catalytic converter
2" downpipes
2-1/2" collector (stock is 2")
o2 sensors mount in same location as stock
Choice of stainless lined flex section or new super flo flex section
Typically no louder than stock
Eliminates the bees in a can sound (exhaust turbulence)
Includes all parts needed for installation
Includes new hanger for catalytic converter
Designed to be installed by the average wrencher with common hand tools
4 year no rust through warranty
10-12 year estimated life-span
they state they also have a version with superflox flex section.
they also say its a 2" downpipe, isnt it suppose to be 2.5"?
whats 2.5" collector?
I must be missing something
Old Jan 30, 2005 | 02:58 PM
Armani
I'm thinking that the part substituted for the flex in the superflo also flexes. eh?
Old Jan 30, 2005 | 06:19 PM
Maximeltman's Avatar
the cat flange is going the wrong way on the superduperflow. id rather have the 'chinese imported crap' as long as it fits onto my cat, ya know?
Old Jan 30, 2005 | 06:30 PM
lilaclucymaxima's Avatar
Team Ramrod
proooooove it
Old Jan 30, 2005 | 07:26 PM
joosdawg's Avatar
did all u guys miss the other post on this? now theres two, go over here and comment so everyone can discuss...http://forums.maxima.org/showthread.php?t=373091
JRod28
Dec 29, 2023 09:56 PM
VQ'ed
69
Aug 27, 2020 12:29 PM
Maxboy23
Sep 8, 2015 06:53 PM
stromm
Aug 27, 2015 04:13 PM
maxipower
Aug 21, 2015 11:10 AM
