Shoter AUTOMATIC SHIFTER
#42
I took someone's advice and used som aluminum tape to cover the rusty colored shifter rod. While I had the console torn aport I used some roofing aluminum and cut a trim piece to cover the stock black one. Before the hole cut in the black piece caused the orange indicator to be in the wrong spot so you couldn't easily see what gear you were in, now with the aluminum piece with the smaller hoe the orange indicator is in the right spot again. Here are a couple of pics....disredard the crackers and messy floorboard.
#43
Originally Posted by Broaner
Yeah, everyone that is too lazy to convert to MT will do this mod. I did it in an effort to lessen the gayness of the auto but it only worked for like four days.
#46
Originally Posted by pavelsmax
is the button on the end of your ebrake handle silver too?
#48
okay kids... dont start getting at eachother.. hehe..
yea llacus.. that looks super duper sexy(i have to stop writing gay things like that..)
man the silver conver under the shifter.. verry nice.. and as far as swap im waiting for tranny to go.. i dotn want to get new tranny when i have a working one..
and yea im not doing this cause im lazy to get 5 speed.. jsut that i want to install a deck in the slide out tray area and i wanted the shifter to give good clearence... other wise i can care less aboutu the shifter.. heehhehe
#53
Originally Posted by Crockpot
How do you go about getting the white plastic peice off the top of the inner rod? Or do you just cut it off and only use the rod itself to press it down? Thanks..
#55
I got sick of the funny looking ball type shifter and went back to the stock one that now sits about 2 inches lower than it originally did. I actually think this looks much cleaner than the aftermarket one I originally had.
I'd sell the ball type auto shifter for cheap if anyone wants it PM.
#58
hey i was wondering if you could buy a regular auto **** with a shift button and wire the o/d button to the shift button and make it a push down shifter? does that make sense? im sure its possible, but im having problems finding a new **** i like so i figured i'd post my ? in the mean time
ilacuss- the stock **** does look better shorter but i liked the ball a lot more. i hate the "OVER DRIVE" on the **** it just looks so stupid to me if it were not there and the **** wasnt so bulky i wouldnt have a problem
#59
I'm defitely doing this mod within a few weeks.
#60
Originally Posted by InsneDrmr
I read the write up on how to shorten it. It seems pretty easy. Any complications in the process? Was it easy to get the stock shifter back on?
#61
Basically the OD button is connected to 2 wires on the stock shifter that can be cut and wired into a switch that is either on the auto shifter (like the levoc models) or it can be wired up to a switch that sits somewhere else. See the pic of the OD button I had for awhile earlier in this post.
The shift lock is just a small metal rod inside a hollow pipe. The black button on the left of your shifter that you push in when you shift just hits an angled white piece of plastic and pushes the rod down to unlock the tranmission.
#63
:o)
ilacuss,
how did you go back to stock when the original 45 degree white plastic piece can't be re-attached...... or can it???? Thanks. And good job.
#64
Originally Posted by ptatohed
ilacuss,
#65
I drilled out the metal rod that was inside the white plastic 45 degree angle piece. Then I just slide the plastic piece down onto the shortened metal rod that sits inside the metal tube. I heated the plastic up first with a lighter so it would sorta melt and stick the rod without wiggleing.
#66
#67
remove shifter ****
Actually, I am trying to get at the shifter solonoid, bcuz my shifter is stuck in N_D position.
Andy29
09-29-2015 06:32 AM
atriuum
09-28-2015 02:19 PM
