cv boots are leaking (driver side) should i replace the whole shaft?
Old Feb 1, 2005 | 06:58 PM
Jonny98max's Avatar
i found out that my cv boots are leaking on my driver side.....is it a good idea to just switch out the whole CV half shaft? i heard cv boots run $20-30 each so wouldnt it be a better choice to replace the shaft and the boots?
i called advance auto parts and they told me a REMANUFACTURED half shaft will cost me only $60 which includes new boots and everything
anyone esle has or have had this problem?
how hard is the install?
Old Feb 1, 2005 | 07:12 PM
JSniper0's Avatar
If it was me i would do the whole shaft, its not that hard. (i'm a person that only settles for the best way) Just look and read around for how-to's. Dont go the remanufactured route because at the shop that I work at we install remanufactured shafts and then once installed we take it for a test drive and half the time their bad so we have to get another.
Old Feb 2, 2005 | 08:08 AM
Hoochiecoochie's Avatar
I had the same problem last summer. I do a lot of my own work but Pep Boys did if for less than $200.00 - reman shaft. For that much, it's not worth doing yourself. IMHO.
Old Feb 2, 2005 | 09:27 AM
optimus310's Avatar
WHAT!!!!
You could have saved about 140 bucks. Its really easy to replace the whole shaft rather than just the boot.
Old Feb 2, 2005 | 09:31 AM
MDeezy's Avatar
its best to just replace the whole shaft unless you dont mind doing all the work required to fix the boot.
Old Feb 2, 2005 | 09:50 AM
big_al's Avatar
Ya, you have to pull the shaft out to replace the boot. Might as well slap a whole new shaft w/ boots that as pre-greased.
Old Feb 2, 2005 | 10:06 AM
Gibby's Avatar
$200?!? I found both brand-new shafts (not re-man.) at O'Rielly for $200 (110+90).
If you don't know how long it's been leaking, just replace the whole shaft.
Old Feb 2, 2005 | 10:14 AM
MDeezy's Avatar
link for oriellys'??
need new shafts also, sounds cheaper than raxles.com
Old Feb 2, 2005 | 12:12 PM
Gibby's Avatar
Sorry, don't know if they have them on the Website. I just ordered them from the local O'Rielly auto parts store. If I have time, I'll check in my garage for the name brand on the axles.
Old Feb 2, 2005 | 01:04 PM
MrDicks95SE's Avatar
Offset Is Everything.
if your boots are leaking, then theres a chance that junk might have gotten inside. its safer and cheaper to replace your shafts and boots at the same time. my boots were leaking so i only had those replaced.
fastcarny
May 18, 2020 10:40 AM
rtirbany
Sep 8, 2015 11:46 AM
shaunkey1
Aug 18, 2015 10:09 PM
BassAddictJ
Aug 4, 2015 11:38 AM
