different clutch feel
Old Feb 3, 2005 | 09:32 PM
vettefever5's Avatar
i had to replace the rear main seal a month ago and while i did it i went ahead and replaced the clutch too, it wasnt shot but i figured id do it while the whole thing was apart. with the old clutch it grabbed towards the top of the travel, and i had no problem doing smooth engagements at low rpms in traffic or whatever, keeping the engine around 1k. now with the new clutch it grabs really close to the bottom which is ok, but whenever i try to do a low rpm engagement the whole car vibrates and feels like its gonna stall. if i rev it up to like 1500 and slip it it engages fine no vibrations. is this just the new clutch breaking in or is there a problem with the clutch, was it somehow installed wrong?? its really aggrivating
Old Feb 3, 2005 | 11:16 PM
Akumachan's Avatar
I never narc'd on nobody.
you just need to get used to your new clutch. mine threw me off completely, and i stalled it twice but you get used to it with time.
Old Feb 3, 2005 | 11:22 PM
Nismo3112's Avatar
Custom User Title
That is because the clutch disc is thicker maybe?
Old Feb 4, 2005 | 12:47 AM
hovz's Avatar
i have same thing since i got a new clutch, only it only vibrates sometimes at low rpm engagement. help please
Old Feb 4, 2005 | 02:14 AM
dayglo's Avatar
mines stock all around and if i let it into 1st at idle it seems like there's a dead spot where it catches, slips then catches again and also vibrates. when i give it a tiny bit of gas to alot of gas its smooth and fine. it just took some getting used to i guess. i also am a bit new with mine but after getting used to the feel of how fast and where to let it out its realy comfortable
Old Feb 4, 2005 | 03:40 AM
SpeedyMaxima's Avatar
I have the same problem its vibrates after i changed my clutch,i asked the mechanic why is it vibrates he said its gonna cost 10$ to fix im not sure exaclty whats the name of the problem that vibrates,but im going to take a pics so you guys can see whats the problem
Old Feb 9, 2005 | 08:43 PM
did he tell you what the problem was? i used to have a 300zx that i replaced the clutch in and nothing like this happened. $10 fix can't be anything too tough i wouldn't think
Old Feb 11, 2005 | 07:16 PM
let me get you a pic's cuz i cant tell you the name of it sorry im just gonna post pic's on the .org
Old Feb 14, 2005 | 10:27 AM
pics might help, ill check whatever your problem was see if its whats wrong with mine
Old Feb 14, 2005 | 11:18 AM
MDeezy's Avatar
when I would just come off the clutch no gas, the car used to shake just a little nothing much at all, but lately vibrates like crazy if I'm just clutching no gas. I think its clutch disc related
I would suggest a bleed, it may not fix the problem but engagement was butter smooth after bleeding, I got out a lot of dirty oil, and realized how rough my engagement was before bleeding
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
