Trans q.
Old Feb 3, 2005 | 11:27 PM
Crockpot's Avatar
Trans q.
On my 95 max (155xxx miles) recently I've had some problems when putting into drive (automatic trans). Before the engine warms up and i shift into drive I get about the same effect of rev'ing the engine up and droping it into gear, a big thunk and lurch. After the engine warms up its fine. I have a few suspisions.. one being a CV joint. The boot was out for a while (unsure of time be4 I replaced it) and I'm thinking this could be part of the problem. I also suspect bad transmission fluid? Ne one have this problem?
Old Feb 4, 2005 | 07:07 AM
goodhead's Avatar
i had this going into reverse it was a torn motor mount, but i would
check/flush trans. fuild, clean screen
check cv by turning steering wheel and seeing if it clicks
with engine supported drop sross membrane and check rear motor mount, poly fill them while your down there
Old Feb 6, 2005 | 12:41 PM
Crockpot's Avatar
ugh.. now I'm stumped... I changed my trany fluid & filter.. she still hops when put into gear... but this only happens when the engine is cold. That rules out the CV joint and motor mount idea. Also now after replacing fluid when my engine is really cold it takes about 2000 rpm from the engine be4 the car starts moving. I think my transmission is dying
Old Feb 6, 2005 | 12:54 PM
Crockpot's Avatar
on a followup question... about how much would a shop charge to replace (parts and labor) an auto trans and also how much they would charge to convert to a 5 spd?
Old Feb 6, 2005 | 12:55 PM
A Flood99's Avatar
how brown was the fluid that you dumped out of there?
if it was pretty crusty, then your tranny might be hurting a little
Old Feb 6, 2005 | 01:00 PM
Crockpot's Avatar
it didnt look bad.. but there was quite a bit of fine metal filings on the magnet
Old Feb 7, 2005 | 10:25 AM
Crockpot's Avatar
bumplestilksken
Old Feb 7, 2005 | 11:55 AM
tavarish's Avatar
fwd gone rwd cr00
is it slipping gears?
Old Feb 7, 2005 | 04:07 PM
Crockpot's Avatar
na it still shifts strong.. I'm just getting moments where its not transvering power to the wheels under 2000 rpms (mostly when cold)
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
carlosvq30
Sep 26, 2015 09:44 AM
