Should I replace the suspension?
Let's say I wanna replace some suspension parts on my car. What would I have to replace in order for the whole suspension to be like new?
The reason I ask is b/c it seems like I can never get the tires to wear evenly and I have come to the conclusion that it maybe worn suspension parts.
I have Sprints with AGX. I am not talking about replacing them,even though I may eventually get some higher springs like H&R, but the parts like control arms,ball joints and what not. All that may not be neccesary but it would give me some piece of mind b/c I plan on keeping the car for alot longer and I want it in as perfect of shape as possible.
I have about 128K on it, so is replacing suspension parts, like I mentioned and maybe even more depending on suggestions, a smart thing to do?
I just need some opinions on what would be worth while to replace.
I would think it would be a good idea to take it to a good mechanic to check for worn parts and only replace what needs replacing. But I’ve tried in the past with a car that had gained a lot of slop in the steering (not Maxima) without getting anywhere.
So, here’s my list of things to check and/or replace:
Tie rod ends (inner and outer)
Ball joints
Bushings
Wheel bearings
Get a Haynes or Chilton manual and it should have procedures for checking/replacing these items.
Poorly worn tires are generally caused by bad ball joints, struts, or alignment.
Check everything out, replace the problem parts and get it aligned.
Ball joints
Bushings
Wheel bearings
Chef N
Sep 22, 2015 11:20 PM
95Maxi
35
Sep 2, 2015 10:37 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
