HID not lighting up, what to do?
Old Feb 5, 2005 | 02:49 PM
Vad3K's Avatar
just installed the Xtec HIDs, the ones from Umnitza, connected the low beam pos and neg to the harness that fits into the ballast, and connected the ballast to the bulb, and the bulb not lighting up. tried both bulbs. whats wrong ?
Old Feb 5, 2005 | 04:21 PM
mansurxk's Avatar
the douchebag f'ed up the pin connectors probalby, you might need to swap them, i think right now its in 9007 mode, so essentially youll be doing a 9004 to 9007 conversion on your headlights then connecting the xtecs to that. thats my guess, and check your fuses after you do that also, i kept blowing them beacuse i ran into a simliar problem. the Prolumen set was in 9007
Old Feb 5, 2005 | 04:36 PM
Gmahoney's Avatar
Ya I just purchased the HID's (9004 kit) I couldnt get mine to work either and I had to rearrange the pins in the blue connector to make it work. The black connected with the black in you stock connector. The double red connects to the green positive. Then my other one didnt light up after I found the problem and I realized that the ballast was bad and im being sent a new one atm
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxie40
Sep 14, 2015 11:28 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
