What Is The Point Of This???
Old Feb 7, 2005 | 07:14 PM
G4nismo's Avatar
i saw this pic and was wonderin what it exactly does b/c i ordered an intake and i saw this at advance auto parts and might do it now. is you do it, how and wht should you plug up the hole on the intake?
Old Feb 7, 2005 | 07:23 PM
WielkiWaac's Avatar
MaximaDriver
Ya. Im interested too. When you unplug that little hose from it, engine runs slower.
What is it for??
Old Feb 7, 2005 | 07:25 PM
G4nismo's Avatar
i'm sure all hoses are too be pluged before driving otherwise could lead to check engine light or other possible disasters. seems like that guy used some kinda rubber thingy to plug it up.
Old Feb 7, 2005 | 07:29 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
breather filter. put the hose back on it. you dont need that on there. you will loose vaccum.
97maxxx's Avatar
yea i tried it once - not worth it - its nto hard to plug up the hole but because of how free that lil filter is and how it really doesnt fit perfect it makes the car idle a lil wierd and and sometimes even seems like it will stall - dont bother doing it - just my opinion
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
the hose that originally goes there is i think the breather hose. by taking it off and just putting a filter on the end of your engine, you get the junk out and it doesnt go back into the intake (i think). by not plugging up the hole on the intake, it could suck up something that could damage the engine, because that hole is after the filter. the engine is also slower because more air is comming in than the ECU knows about.
Old Feb 7, 2005 | 07:32 PM
G4nismo's Avatar
wow thanks a lot, i will make note to self about that when installin my intake
Old Feb 7, 2005 | 07:37 PM
G4nismo's Avatar
"A breather filter relieves your engine of positive crankcase pressure and recycled carbon vapors from your engine, which cause loss of throttle response due to build-up on the throttle body. The Dragon Breather from weapon r, helps resolve that problem, by venting the vapors into the atmosphere."
i just saw read this from somewhere but sounds like bs to me.
Old Feb 7, 2005 | 07:39 PM
Vlasic's Avatar
^^ i believe thats true. but you dont need a special weapon r filter, any filter of that size will work.
Old Feb 7, 2005 | 07:42 PM
DR-Max's Avatar
Every other aftermarket intake out there is bs IMHO. Just my 2 cent. You'll only see gains from an intake if you combine it with y-pipe/b-pipe. Increasing intake flow will do not good if you don't open up the exhaust accordingly.
Old Feb 7, 2005 | 07:59 PM
G4nismo's Avatar
yes i no, i'm gonna get a ypipe soon hopefully and i think i have a custom b-pipe cause i had to get it replaced a while ago. what does imho stand for, can't figure it out.
Old Feb 7, 2005 | 08:43 PM
2muchmax's Avatar
i tried putting that filter and i put like 2 clamps very tight fit and i get low idle / stall . it means in my humble opinion?
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Nov 6, 2015 02:34 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
