Crank NO Start--Any Ideas? PLZ HELP!!!
Old Feb 8, 2005 | 11:30 AM
Viking155's Avatar
My Max used to missfire(backfire) randomly. It got to be worse in the last couple of weeks and now the car is DEAD. Died on Superbowl Sunday, tried starting it but no luck. Actually I started it for about three seconds, and it died for good. Its a 99 Max with 100,000 miles, 5sp. PLZ HELP IF YOU CAN
Old Feb 8, 2005 | 11:56 AM
slizan99's Avatar
MAF, crank postion sensor, cam position senor, NATS issue, Engine fuses. Start with these and go from there.
OR maybe you should check for codes.
Old Feb 8, 2005 | 11:58 AM
nismology's Avatar
Try replacing your fuel filter.
BTW, no need to make 2 threads about the same thing.
Old Feb 8, 2005 | 12:05 PM
Viking155's Avatar
NATS issue
What do you mean? I checked the fuses and the sensors, no luck. No codes at this time. The original problem was that the car was misfiring, but it never told which coil. I had codes like: random misfire, knock sensor, running lean. Cleared them a while ago and they never came up again. Car started missfring more than ever lately and the CEI light just started blinking and now the car is completely DEAD.
Old Feb 8, 2005 | 02:12 PM
slizan99's Avatar
Completely dead as in won't turn over? Or as in turns over, but won't start? When you try to start what does the security light do? If the CEL was blinking then there should be at least one code. You should have at least the KS code (if you haven't replaced it yet).
EDIT: NATS is the chip-in-key security feature in all 99+ maximas.
Old Feb 8, 2005 | 04:47 PM
Viking155's Avatar
It turns over, but does not start
Old Feb 8, 2005 | 04:56 PM
Viking155's Avatar
The security light stays lit solid. Is that ok?
Old Feb 8, 2005 | 05:31 PM
RichMax's Avatar
Boosted like Snipes tax refund
Solid security light indicates NATS/NVIS problem. Try just unplugging your battery.
Old Feb 8, 2005 | 06:41 PM
slizan99's Avatar
Disconnecting the battery most likely won't work. You'll need a consult or a locksmith with some expensive equipment. If the light is solid, then that's a NATS / NVIS problem. NATS stands for Nissan Anti-Theft System. NVIS stands for Nissan Vehicle Immobilzer System.
Old Feb 8, 2005 | 06:46 PM
Viking155's Avatar
Yeah the light stays on, when I try to crank the engine. Do those chips go bed a lot? What happens to the car when you have a bad chip? I got mine started, it shut off after 5 seconds and that was it, does not run anmore. Is there any way you can bypass NVIS? Thanks.
Old Feb 8, 2005 | 06:55 PM
slizan99's Avatar
Sometimes they just lose their memory. I've seen it quite a bit recently. There's no way to bypass it. You need to get your keys re-registered.
Old Sep 24, 2011 | 04:00 PM
tigersharkdude's Avatar
Originally Posted by jetsfanez
Might be a problem in the pistons.
BAN
Why you ask? you just bumped a 6 year old thread. Why did you do that? just trying to increase your post count
Old Sep 24, 2011 | 04:05 PM
asand1's Avatar
Reported.
Old Sep 24, 2011 | 04:11 PM
SandyMax96's Avatar
I was gonna jump on it too, but seeing that his post count is 1, I just decided to let it be. Lol. It's not like he knew that the 99s are NOTORIOUS for having that retarded A$$ NATS problem, but that's just me
Old Sep 24, 2011 | 04:17 PM
the guy just made a random post trying to up his post count.
Old Oct 3, 2011 | 07:15 PM
Flynnsmax's Avatar
It would be nice to know what the problem was. I have a 95 and it ran 3 months ago. Went to start.it so I could drive it in the winter and all it does is crank over. I been searching and no luck.
Old Oct 9, 2011 | 08:07 PM
sdot126's Avatar
Try the ground from tranny to body
Old Oct 9, 2011 | 08:23 PM
Fauken's Avatar
Dude, this Thread is 6years old, try and comment on something more recent and still circulating instead of posting random shiz on old threads.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
Justin Kroll
Oct 1, 2015 07:03 PM
zmcneely13
Sep 26, 2015 02:26 PM
