installing SS clutch line, need help QUICK
Old Feb 10, 2005 | 01:01 PM
Akumachan's Avatar
I never narc'd on nobody.
ok, so i got the hose off the slave cylinder itself, though it was a tight fit, i got it done no problems, but the real problem arose when i tried to get the old line unbolted from the hardline, where it attaches to the bracket thing. i found i little... tensioner plate? and pulled it out, so now the bolt moves freely in the bracket, but i cant seem to get the bolt undone. i must use an open ended wrench, but the bolt is just being destroyed instead of coming loose. visegrips wont work either, but ive sprayed more than enough WD40 on that thing. my question is, is there any trick to this that im overlooking, or is it just flat out impossible to remove intact?
and by the way, yes, i checked the stickyies, but they dont cover this particular install.
Old Feb 10, 2005 | 01:13 PM
Akumachan's Avatar
anybody even wanna look at this? c'mon guys, i gotta get this thing put back together and get to school.
Old Feb 10, 2005 | 01:25 PM
risingmist's Avatar
i cahnged the same line, everything came off without a hitch.
Old Feb 10, 2005 | 01:29 PM
Akumachan's Avatar
so no tricks, mine just hates me... crap. do you remember if that bolt is 10mm? the 9mm wont fit, so i assumed its 10, cuz i dont know if theyd be mean enoguh to use some kind of 9.5mm or something. anyhow, carp, thanks anyways
Old Feb 10, 2005 | 01:31 PM
risingmist's Avatar
no in pretty sure it was a 10mm. if that doesnt help try using US mesurements. damn i forget how to call them.
Old Feb 10, 2005 | 01:33 PM
Taken2DaMax's Avatar
The same thing happened to me. The bolt took forever to get loose. I excessively used alot of WD40 and stripped it. The bolt is a 10mm bolt. The way I solved it was to buy a 10mm flare wrench and dry off all the WD40.
Old Feb 10, 2005 | 01:34 PM
Jeff92se's Avatar
I'm needing a caw
Needle nose vice grips.
Old Feb 10, 2005 | 02:46 PM
Akumachan's Avatar
umm, im a noob to tools i guess, but whats a flare wrench, and can i get one at a hardware store, or is it special?, and the visegrips are just destroying that poor nut.
maxima-junky
Oct 21, 2015 05:17 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
N2deep
Aug 16, 2015 08:30 PM
maxima-junky
Aug 13, 2015 09:59 AM
