Engine hesistates during acceleration
Old Feb 11, 2005 | 05:45 AM
mbb6's Avatar
changed plugs, use to jerk a bit during stops, tested ignition coils, although aware that even though it test positive, the coils may misfire still. need to know if this is a fuel managment problem, as in fuel filter or even spark plug wires. Codes came up as p1320 and p0300 cannot find these codes in the other thread.
PS autozone gives a free obdII reading upon request, if people did not know.
Old Feb 11, 2005 | 04:22 PM
Batxel's Avatar
blah
P1320 --- 0201 - Ignition Signal Circuit
P0300 --- 0701 - Multiple Cylinder Misfire detected
Check your spark plugs make sure they're torqued to spec (14-22 lb/ft). Check your coil packs again , the haynes manual shows to do it assuming the people at haynes are know it all's. If you have a '99 its time to start buying new coil packs from what I read.
Old Feb 12, 2005 | 11:43 PM
Goran's Avatar
My car does the same thing. I also got the code 0201. Thats the only code I got. Could it be that its spark plugs or its ignition coil for sure??
Old Feb 13, 2005 | 05:13 AM
maxima_kenny96's Avatar
my 96 se....has some MAJOR acceleration problems, I will have it floored and I'll sit there doing 40....5 seconds later...45
Old Feb 13, 2005 | 05:14 AM
jackiss2888's Avatar
coilpacks...
Old Feb 13, 2005 | 05:34 AM
JClaw's Avatar
Knock sensor?
jerrod99_se-l
Sep 16, 2015 02:39 AM
seesole
Sep 14, 2015 12:38 PM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
