help with code 0407 (crankshaft position sensor)
Old Feb 11, 2005 | 07:57 AM
pavelsmax's Avatar
hey so my check engine light has been on for a little while now and of course with it being cold, me being lazy, and the car feeling like it was fine i havent gotten around to checking it...
i did this morning and it came out 0407 which means
0407
Diagnostic Trouble Code 0407 indicates a malfunction was detected when...
A) 120 degree signal is not entered to ECM for the first few seconds during
engine cranking.
B) 120 degree signal is not entered to ECM during engine running.
C) 120 degree signal cycle excessively changes during engine running.
Possible causes...
- Harness or connectors
- Crankshaft Position Sensor (REF)
- Starter motor
- Starting system circuit
Perhaps a marginal starter would crank the engine at a non-uniform rate (fast-slow-fast-slow) and disrupt the normal rhythm of pulses from the CPS. This is consistent with the starter motor problems you have recently reported.
i am not having any problems starting the car even on really cold days so i dont think the starter is the cause... anyone have any info on this problem
also i never got a haynes manual before but im ordering one now... wasnt there an online version if anyone has that link could they please post it
thanks
danny
Old Feb 11, 2005 | 10:52 AM
gabex's Avatar
I have a Crankshaft Position Sensor (REF) available. I bought it and did not end up needing it. Brand new, in box. Let me know if you'll need it.
Old Feb 13, 2005 | 09:43 AM
pavelsmax's Avatar
hey thanks i reset my ecu... will the light come back on if the problem is recogized again?
i guess if the light comes on and you still have the sensor i'll pick it up from you
how much do they run?
Old Feb 13, 2005 | 10:04 AM
mansurxk's Avatar
any hard starts or intermittent cranking will trip the CPS code. i had it before, because i had hard starts. turned out the CPS (POS) sensor was dirty instead of CPS (REF 0407) burned the starter out, then realized it wa sthe other sensor.
Old Feb 13, 2005 | 11:16 AM
chenzarino's Avatar
Yea just clean both crank sensors and make sure the wiring is plugged in tight. I had the wiring clip pop off one of mine and my car died right in the middle of the road. Thank god I knew how to pull the codes and have a manual, other wise woulda cost me hundreds of dollars to have a sensor plugged in.
Old Feb 13, 2005 | 11:21 AM
gabex's Avatar
So just try and figure out if you will end up needing the sensor replaced or not. If it comes down to it, yeah I have one. I don't think its going anywhere Just PM me if you end up needing it. Thanks
Old Feb 13, 2005 | 01:30 PM
PLUMMAXSE's Avatar
Anyone know the size of the rubber gasket that fits on crankcase postion sensor? Got a small oil leak and thought I'd replace it. Thanks!!
Old Feb 14, 2005 | 12:59 PM
pavelsmax's Avatar
thanks for the help everyone... im gonna get under the hood hopefully this weekend if its semi warm and check the sensors mentioned above
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 23, 2015 08:46 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
