DIY Power Steering Flush
Old Feb 12, 2005 | 07:04 AM
kxmike's Avatar
I`m looking to flush the power steering system in my Max myself. I just can`t see paying somebody else $70-$100 for something so simple. Anyone know of a good do it yourself kit? I have seen some flushing fluids that you can use without a machine by disconnecting the return line and pouring the flush into the reservoir while turning the wheel back and forth.
Old Feb 12, 2005 | 08:30 AM
njmaxseltd's Avatar
I use the turkey baster method and suck out the reserve a few times and refill it. Do that over a period of a day or two using 2 bottles of PS fluid and you should have a nice refresh of the fluid in the system. Do that every 6 months or so and the system should stay pretty clean.
Old Feb 12, 2005 | 08:31 AM
Bobo's Avatar
Check the 1st sticky in the Fluids and Lubricants forum.
Old Feb 12, 2005 | 10:18 AM
RastaManMax's Avatar
Instead of using a turkey blaster, i used this other suction device i got from Wal-Mart for about $3 or so. It has a thin extension so you can suck almost all of the fluid out of the resoviour. Mind you if you already have a turkey blaster, that should do the job sufficiently as well. What i would suggest is that you suck up as much as possible, refill and then 2 weeks later, repeat if it's your first time. That got mine to stay a nice Amsoil red.
LEMAR
Old May 11, 2005 | 10:09 AM
dashingMax's Avatar
Suction Device
LEMAR
Could you tell us what is this "suction device" called? A pic would be greatly helpful!
Also, is it okay to have fresh fluid mixed with dirty fluid? Would that cause any problems?
Thanks.
Old May 11, 2005 | 10:39 AM
renatonetmail
I got mine at Pepboys and its a pump like the bicycle air but with rubber hose1 on one end and and rubber hose2 on the other one. take any liquid from rubber 1 to rubber 2 hand pumping it. it cost me...i dont even remember so it wasn't expensive believe i would of.
Old May 11, 2005 | 10:48 AM
dashingMax's Avatar
Actron Vaccum Pump @ PepBoys
Is this it? Actron Vaccum Pump on the LEFT.
Old May 11, 2005 | 10:55 AM
renatonetmail
nop.... that was like $30 something dollars. Mine was a pretty basic one...
Old May 11, 2005 | 10:58 AM
renatonetmail
this is the one i bought:
http://www.acehardwareoutlet.com/pro...manu=&narFlag=
Old May 12, 2005 | 07:49 AM
dashingMax's Avatar
Hand pump by Northern Tools
Found another one. Wonder if this can be used to suck-out fluid. $35 on NextTag.com
http://www.northerntool.com/webapp/w...ite=Performics
Old May 12, 2005 | 08:41 AM
nadir_s's Avatar
vicodin ... gift of life
damn so changing the power steering fluid is as easy as sucking it out and putting in new fluid a couple times during the day or two? interesting ....
isn't changing it every 6 months too frequent?
Old May 12, 2005 | 09:47 AM
Crockpot's Avatar
what else would it be used for??
Old May 12, 2005 | 09:49 AM
Maxima 504's Avatar
damn my fluid I replaced the red with is clear now. It was Valvoline with conditioner and stop leak. I like the clear over the dirty red fluid that I had in there..
Old May 12, 2005 | 09:52 AM
renatonetmail
Originally Posted by Maxima 504
It was Pantene-ProV with conditioner and stop leak.
What??????
Old May 12, 2005 | 10:03 AM
njmodi's Avatar
Do I get a tax break?
It is a hand pump. It can be used to pump the liquid out of the 5-gallon tub into wherever you want.
Old May 12, 2005 | 10:12 AM
nismology's Avatar
Ummm...to pump out fluid???
Old May 12, 2005 | 04:04 PM
dashingMax's Avatar
Wiseguys...eh?!
Awright wiseguys! :-)
I meant, could we use this pump to extract brake fluid from the car's reservoir into the bucket?
Old May 12, 2005 | 04:15 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
I don't see any reason for Replacing Power steering oil. There is not many moving parts in power steering system. It is not like the car engine oil, or the Tranny oil.
Old May 12, 2005 | 07:20 PM
dashingMax's Avatar
I beg to differ...
Normal driving eventually causes power steering fluid to be affected by heat, friction and electrochemical degradation. The higher pressure created by hard turns is especially damaging over time. Your power steering fluid starts out clear but eventually turns dark with age. Sludge and varnish build up and prevent the easy turning and responsive handling you have become accustomed to.
A power steering flush safely removes varnish and sludge deposits. It is also the best way to remove wear metals that slowly grind away the power steering internal components, including the power steering hoses, power steering pump, rack and pinion and/or gear box. A Power Steering Fluid Flush thoroughly cleans the vehicles steering system and protects it because the fresh power steering fluid and conditioners revitalize the seals and o-rings.
Flushing Power Steering Fluid at least every 30,000 miles will greatly reduce the chance of premature failure and may result in better handling.
...and no I am not selling anything :-)
Cheers!
Old May 12, 2005 | 08:28 PM
Crockpot's Avatar
omg, note the obvious sarcasm.. he asked if it could suck out fluids, well yeahhh.
Old May 12, 2005 | 08:49 PM
nismology's Avatar
I beg to differ...
Cheers!
Copy and paste?? Our power steering fluid is Dexron III automatic tranny fluid, which is definitely NOT clear. Proof enough that you didn't come up with that yourself.
Old May 12, 2005 | 09:22 PM
Thanks.
Sorry i don't have it nor my digital camera with me in school, but it's pretty basic. It's used to mix gas.
Mixing fresh and dirty fluid won't cause any problems. The mix will also be very diluted if you cycle out the old fluid 2 times anyways.
LEMAR
Old May 13, 2005 | 05:31 AM
CystumMax's Avatar
I beg to differ...
Cheers!
You are definitely Brain washed by this concept. Under normal Driving condition, your power steering does not even heat up, unless you are drifting or something. I don't know where you got all of this information.
Old May 13, 2005 | 10:18 AM
dashingMax's Avatar
Indeed!
Yes, copy and paste indeed. I never claimed it was mine!
Old May 13, 2005 | 10:37 AM
Max96GLE's Avatar
Just drain out some Power Steering/ Automatic transmission fluid with a liquid soap dispenser pump. Kind of cheesy, but works like a charm.
Old May 13, 2005 | 10:39 AM
njmodi's Avatar
AWESOME POST! and Great IDEA!
Old May 13, 2005 | 01:22 PM
crapsack's Avatar
that is brilliant
Old May 13, 2005 | 01:49 PM
darkstar56580's Avatar
Damn, nice idea.
Old May 13, 2005 | 02:15 PM
Max96GLE's Avatar
Here's a picture of the pump.
Old May 13, 2005 | 04:49 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
i just used a turkey baster. $2 at target. Make sure you use DEXTRON ATF and not actual power steering fluid. It should be BRIGHT RED.
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
RWCreative
Sep 21, 2015 11:01 AM
ChrisIve
Sep 21, 2015 12:01 AM
ColdCananda
Sep 20, 2015 10:45 PM
