Rear camber adjustment kits?
Old Feb 12, 2005 | 08:44 AM
josehernandez94's Avatar
I'm looking to get some Tein Basic Coil Overs and do a pretty substantial drop. However, I've only been able to find a camber adjustment kit for the front, not for the rear. Do any rear adjustment kits exist? If not, how does that affect the camber?
Old Feb 12, 2005 | 11:04 AM
RA030726's Avatar
I'm nutty for Nissans
The rear axle is one piece so as you lower the car the wheels stay the same relitive to the ground. NO camber correctons needed....also no alignment needed.
Old Feb 12, 2005 | 11:49 AM
Great, thanks a lot for the info man.
Old Sep 24, 2008 | 11:33 AM
RDroz's Avatar
I'm bumping this for confirmation of what JSutter says above.
I'm 10,000 kms since my 1.5" drop and I can see inside wear on all 4 tires. Up front I'll get camber bolts ASAP, but the rear of course is non-adjustable.
So the question is.....does that odd rear suspension (not independant - not solid axle) change camber with height? It seems to me that it does and there isn't a darn thing I can do about it other than buy tires fairly often!
Old Sep 24, 2008 | 11:45 AM
mtrai760's Avatar
'Trynna' is not a word
Make sure your beam is centered after lowering (Search for how-to). Only other thing you can do is get the beam bent to change the camber (in the Search again).
Old Sep 24, 2008 | 12:17 PM
MorpheusZero's Avatar
Yeah the alignment in the rear is static, only way to adjust it is to bend the beam or (possibly) get some full contact shims.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
