can't get clearance lights off
Old Apr 30, 2001 | 01:14 PM
Mike'z Max
i'm trying to put blue bulbs in my clearance lights and front side markers. the front side markers popped right off, but i can't get the clearance light off. it says there is one screw on top, i took that off, and then it says to take a flathead screwdiver and pop the light off. only it won't go, and i don't want to break it. someone help me while its still nice out.
thanks
mike'z max
Old Apr 30, 2001 | 01:19 PM
Hercules's Avatar
You can wrap some towels around a screwdriver, and pry the rear section (towards the wheel) of the clearance light. It should come loose. Just don't use too much force, or the light will chip/break. When I removed mine, I also sprayed WD-40 at the joints to make removal easier.
Old Apr 30, 2001 | 01:40 PM
Dreizehn's Avatar
Pain in the _$$
The first time you pop them off it's real hard to do. You think you are going to break something. Just put your screwdriver as close to the bottom of the light as possible, (closest to the bumper) and pry. Sorry no easy solution.
Old Apr 30, 2001 | 01:59 PM
punabuds's Avatar
I agree with the previous posts, using the screwdriver at the bottom of the light is the way to go. Make sure you use a cloth or something. WD-40 will help out alot for you too. If you look in between the headlight and the clearance light you should be able to see the little **** that inserts into the car. Get the WD-40 on that bad boy and pry. I found it was a pain the first time, mostly because I didn't know exactly how the light attached and detached from the car. Now that I know, it's a little easier to get off.
Old Apr 30, 2001 | 02:03 PM
Mike'z Max
thanks,
i got it off....finally, never sweat or swore like that, only to find the guy at the import store sold me the wrong bulb. it only had one head instead of two. what the f8. anyway, i'll be back at tomorrow.
lowpost99
Oct 26, 2025 06:53 PM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
