Wheel Moves from side to side
Old Feb 15, 2005 | 08:48 AM
coles727's Avatar
HI there,
I just have a question about my steering I assume?
When Im driving around 50 or less the steering wheel wiggles left and right and left and right, moves only about 1/2 an inch each time, even when my hands on the wheel! is this a bearing or something?
Old Feb 15, 2005 | 09:07 AM
|Bijan|'s Avatar
UCF Lexus
Sounds like your alignment if off...
Old Feb 15, 2005 | 09:27 AM
njmaxseltd's Avatar
Out of round rim or bad tire.
Old Feb 15, 2005 | 09:40 AM
hacim105's Avatar
You probably need:
Alignment
Tires Balanced and Rotated
I think that sometimes warped rotors can affect that also, but I wouldn't definitely do the first 2 before trying anything else.
If that doesn't work then your powersteering might need to be fixed.
Old Feb 15, 2005 | 09:59 AM
adithius's Avatar
#1 Your alignment & wheel balance is probably off
#2 Your steering might need to be tightened
#3 If this happens when you are breaking, then your rotors are warped
#4 Check your rims for any damage
Look at your tires to see any uneven wear
Old Feb 15, 2005 | 10:02 AM
jbreit's Avatar
ask for a dynamic balancing on your wheels. This is different than static balancing and will improve the steering wheel wobble you have.
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
BassAddictJ
Aug 4, 2015 11:38 AM
