Possible Tranny leak/ Redline MT-90 Fluid
Old Feb 15, 2005 | 03:01 PM
Nismo3112's Avatar
Custom User Title
Over the past few days I noticed a wet spot underneith the car where I park. So today I jacked the car up on the driver side to take a look, and all of a sudden, fluid starts dripping at a rapid rate... SO I look where its coming from, and it looks like its coming from the passenger side axle seal, where the axle goes into the tranny.
This is what confuses me.
When I did the swap, I used Redline MT-90 tranny fluid, but forgot what color it was..... The fluid that was leaking was clear/yellowish.
This is the same exact color as DOT3 brake fluid, of which I spilled some on my tranny when I was installing an SS clutch line.. << This was about 2 weeks ago.
I am stumped. Does anyone know for sure what color the MT-90 fluid is? I am hoping it's just the brake fluid I spilled. If it is the bearings, I guess it's time for a rebuild.
BTW: the tranny has around 68k miles on it. From a 97 SE. Does this seem about right for the diffy bearings to fail?
Old Feb 15, 2005 | 03:04 PM
Jeff92se's Avatar
I'm needing a caw
I'm gonna guess red. Just grab the axle and try to move it up/down. If it moves alot and if the fluid starts pouring out, your tranny bearings are shatola
Old Feb 15, 2005 | 03:05 PM
96white's Avatar
redline mt 90 is red 100% sure
Old Feb 15, 2005 | 03:06 PM
Nismo3112's Avatar
Custom User Title
I tried moving the axle up and down and sideways, but it wouldnt budge. BUT the seal was pretty dang wet.
Old Feb 15, 2005 | 03:08 PM
MDeezy's Avatar
the diffy problem usually occurs around 80K+ based on many posts from other who have had this problem
Old Feb 15, 2005 | 03:11 PM
mansurxk's Avatar
if your axle didnt move, it spossible that the seal went bad, its half hour at most to replace and problaby cost you $60 at a trusted mechanic.
Old Feb 15, 2005 | 03:12 PM
Nismo3112's Avatar
Custom User Title
^^ Hmm, The seal has only 6k miles on it.
Old Feb 15, 2005 | 03:16 PM
Jeff92se's Avatar
I'm needing a caw
Is the axle all the way in?
Old Feb 15, 2005 | 03:17 PM
Nismo3112's Avatar
Custom User Title
As far as I know.. the car drives fine, but I will have to double check.
Old Feb 15, 2005 | 03:32 PM
SkoorbMax's Avatar
I'm pretty damn sure that MT90 is NOT red, but rather a yellow/amber color. I have some at home, so I need to check, but I really can't recall it being red. I know that the stuff I replaced it with (and also the stuff in my 97) both were yellowish/amber, and I don't recall redline being red :Q
Old Feb 15, 2005 | 03:35 PM
Nismo3112's Avatar
Custom User Title
This sucks. I am beginning to think that the bearings are definantly shot. The past 6k miles I certainly haven't been taking it easy on the car.
But thinking positive, I am probly going to wait until I do the 3.5 swap to do the tranny. That way I can do it all at once while everything is out.
Old Feb 15, 2005 | 03:36 PM
Jeff92se's Avatar
I'm needing a caw
It can still drive fine and not be all the way in.
Nismo3112's Avatar
Custom User Title
^ I will check the 3 bolts that are supposed to keep the pass. side axle in place.
Old Feb 15, 2005 | 03:38 PM
Jeff92se's Avatar
I'm needing a caw
Oh pass side. Sorry. Hmmm you might have damaged the seal while putting in the axle. But if it doesn't move up/down then I have to guess the seal (however new it is)
Old Feb 15, 2005 | 03:52 PM
96white's Avatar
To me it looks red but i understand the color your talking about.
user 11122324
42
Jul 18, 2022 03:35 PM
fx4five
Oct 18, 2015 06:57 PM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
