how to check 5-spd gear/tranny oil?
Old Feb 16, 2005 | 10:03 AM
tallica62's Avatar
i know there are stickies on it, but the link didnt work and im in kind of a tight squeeze here. I have a leak from my 97 SE and i need to check my gear oil/tranny level so i dont burn out my tranny. Can anyone help me with this...i have no idea how to check for this fluid or where its located. Anyone have any links that work or pics or what...i need to get it done today. thx
Old Feb 16, 2005 | 10:24 AM
Chief Brody's Avatar
I am curious as to if there is a backup for the write up to this as well. The site that is supposed to host it seems to be in the process of updating things. May just want to get a Haynes/Chilton manual. Would be a good idea to change the oil while you are at it. That's what I plan to. I am too relient on nice little write ups.
Old Feb 16, 2005 | 11:43 AM
Ok, go to the fluids/lubricants section. There is a write up there. I have been here a while and have never gone to that forum. Looks good to me.
Old Feb 16, 2005 | 11:48 AM
SkoorbMax's Avatar
Fluids section should be good, but in short there is a large screw/bolt (size of a quarter) that you put a 1/2 ratchet or breaker bar into, and undo the screw. Putting your finger inside the fluid should be just up to level with the hole, so that anymore and it would start to pour out.
To get at that will likely need to jack the car up, then unscrew it, then either feel with your finger at that point, or gently lower it again (so that it's perfectly flat), and feel with the finger
It's a good idea to check; running out of tranny fluid cost me a transmission in an old accord.
kjlouis
Oct 3, 2015 05:29 AM
dcam0326
Sep 18, 2015 04:52 PM
ag90fox
Sep 9, 2015 12:22 PM
