only driver power window and lock working
Old Feb 16, 2005 | 11:30 AM
fulltop74's Avatar
The other 3 doors dont work at all, I have checked the fuses they look good. Any body else have this problem?
95' GXE 5spd
Old Feb 16, 2005 | 11:54 AM
matty's Avatar
Theres a button on your door panel that locks out all the other doors...try that..its probably pushed down
-matt
Old Feb 16, 2005 | 01:49 PM
fulltop74's Avatar
I checked the little button on the door panels and were all functional. Has this happened to anybody else? Help appreciated.
James
Old Feb 17, 2005 | 02:06 PM
fulltop74's Avatar
Damn...I cannot figure out what is wrong? This is driving me nuts.
Old Feb 17, 2005 | 02:23 PM
RockinTheDecks's Avatar
maybe something in the wiring of the door/window lock on the drivers door? i know you said its not pushed down, but maybe something is wrong with the harness and it think it is depressed. i dunno
Old Feb 17, 2005 | 03:20 PM
PAREDLINE's Avatar
can you control all the windows and locks from the drivers side control? Or does that not work either?
Old Feb 17, 2005 | 03:25 PM
fulltop74's Avatar
I can only control the driver lock and window, the other locks and windows cannot be controlled at all. Thanks
Old Feb 17, 2005 | 03:30 PM
PAREDLINE's Avatar
Thats not what I mean. When you sit in the drivers seat and on the drivers door panel switch... if you move all the buttons up and down, do all the windows go up and down? Or is the drivers window the only one that works from that switch.
This is important because the drivers switch actually controls ALL the windows. Even though a window switch is on every door, its routed through the drivers switch.
It might be a good idea to find a friend with a maxima and borrow his switch and test it on yours. You might have a bad switch. If the switch isnt bad then you have relays under the hood. You might have a bad relay.
If the switch and the relays are good, the wiring from your window/door lock switch on the drivers side should be tested for continuity. This is a process thats hard to describe here. But you have some starting points to look at. Post again and let us know what happens
Old Feb 17, 2005 | 04:03 PM
Black Maxima
I'll send you a driver's switch piece for free. All it needs is the LED board inside, which you can take from your other one. Halla at me dawg...
fastcarny
May 18, 2020 10:40 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
