Y-pipe use with stock piping
Old Feb 17, 2005 | 12:30 PM
A Flood99's Avatar
i have a question about backpressure when adding a Y-pipe while keeping everything else stock...
will i have abnormal backpressure which might affect exhaust flow out of the engine.......and also do aftermarket Y-pipes use larger diameter piping than the stock Y?
Old Feb 17, 2005 | 12:32 PM
mzmtg's Avatar
Minister of Silly Walks
Dont worry, you still get plenty of power using the stock cat back.
The Y-pipe outlet is 2.5". This is the same size as the inlet on the OEM cat.
Old Feb 17, 2005 | 12:33 PM
maxima_kenny96's Avatar
yea, dont worry about ur back pressure. Just keep your cat on, unlike me...who was to take it off and fry everything due to no back pressure BUT ANYWAYS!! yeah, the Y-pipe would be a great investment for u right now.
Old Feb 17, 2005 | 12:36 PM
mzmtg's Avatar
Lies.
Old Feb 17, 2005 | 12:37 PM
A Flood99's Avatar
so there is no difference in the diameters between the stock and aftermarket y-pipes?
i didn't know the inlet for the cat was 2.5", if that's so then basically Y-pipe diameter doesn't change when going aftermarket.....just the pre-cats are removed
or am i still missing something
Old Feb 17, 2005 | 12:39 PM
mzmtg's Avatar
The aftermarket pipe diameter is larger than OEM. But it's not larger than the cat openings.
Old Feb 17, 2005 | 12:41 PM
Jeff92se's Avatar
I'm needing a caw
There is also no such thing as back pressure
Old Feb 17, 2005 | 12:42 PM
A Flood99's Avatar
ok, that makes sense, just trying to grasp how i'm going to put on a Y pipe while keeping everything stock
i take it the most an aftermarket Y differs in diameter is +.25"
mzmtg's Avatar
Sure there is. It can be measured.
Old Feb 17, 2005 | 12:43 PM
Jeff92se's Avatar
I'm needing a caw
Go ahead and get that for me
Old Feb 17, 2005 | 12:45 PM
mzmtg's Avatar
If you insert a static pressure probe at the upstream end of the exhaust system, you can measure the pressure. In automotive parlance, this is called "backpressure."
To normal people, it's just called "pressure."
It's just terminology.
A Flood99's Avatar
well i just used back pressue because i've heard that term somewhere......i'm just worried i may improperly alter my exhaust flow due to having stock header diameter, increased Y-pipe diameter, and stock catback diameter(mainly concerned about restrictive B-pipe)
but maybe getting exhaust out of my engine is not as complex as i make it out to be
Old Feb 17, 2005 | 12:46 PM
mzmtg's Avatar
It's not. Less back pressure is always better.
Old Feb 17, 2005 | 12:47 PM
A Flood99's Avatar
also mzmtg, i read on another forum that you have a leaking front caliper........if you have ABS i can help you out since i've got two good looking calipers i took off my max, just tell me left or right and its yours, just pay shipping
Old Feb 17, 2005 | 12:48 PM
Jeff92se's Avatar
I'm needing a caw
You might have a case for "resistance to flow pressure" but there is no "back pressure". Only exhaust gas velocities. Becuase I didn't see any flowing backwards from the tail pipe to create any "backpressure". hehe
Jeff92se's Avatar
I'm needing a caw
That is incorrect.
mzmtg's Avatar
It's still the pressure that the engine must overcome to move the gas through the pipe. Call it whatever you want.
Old Feb 17, 2005 | 12:49 PM
mzmtg's Avatar
That is incorrect.
When is backpressure a good thing?
Notice I only mentioned pressure, not velocity...
Old Feb 17, 2005 | 12:50 PM
Jeff92se's Avatar
I'm needing a caw
I'll call it by it's correct term. Exhaust gas velocity
Old Feb 17, 2005 | 12:52 PM
Jeff92se's Avatar
I'm needing a caw
Because there is not backpressure. No such thing.
mzmtg's Avatar
Pressure is always a factor when dealing with fluids flowing through pipes.
A Flood99's Avatar
gotta run to class, i'll be coming back to this later
mzmtg, above i put up about a caliper....lemme know if you want it
Old Feb 17, 2005 | 12:56 PM
mzmtg's Avatar
Let's all read the basics about pumps and piping systems...
http://www.roymech.co.uk/Related/Pumps.html
Old Feb 17, 2005 | 12:58 PM
Jeff92se's Avatar
I'm needing a caw
You can look at from a pressure standpoint if you wish. I'll look at it from a velocity standpoint.
Old Feb 17, 2005 | 01:00 PM
mzmtg's Avatar
They are related. One affects the other.
Old Feb 17, 2005 | 01:03 PM
Jeff92se's Avatar
I'm needing a caw
I can ignore the pressure aspect if the velocities are high. But can if the "backpressure is low" will the velocities be high?
Old Feb 17, 2005 | 01:05 PM
mzmtg's Avatar
In a properly designed system, one can minimize pressure while maximizing velocity.
Old Feb 17, 2005 | 01:07 PM
Jeff92se's Avatar
I'm needing a caw
But you just said "the less backpressure, the better". Nothing about velocities at all. By just saying that, the person should install a 3.5" exhaust system to lower the "backpressure" as much as possible.
Old Feb 17, 2005 | 01:10 PM
mzmtg's Avatar
Pressure acts in all directions, regardless of flow direction.
So there.
Old Feb 17, 2005 | 01:12 PM
Jeff92se's Avatar
I'm needing a caw
How much pressure is exerted directly backwards in the flow of the exhaust pipe? More than the 1 bar that is already exerted at the other end?
So there.
Old Feb 17, 2005 | 01:14 PM
mzmtg's Avatar
Yes. The pressure inside the pipe must be higher than atmospheric, or the exhaust wouldnt flow out of it. Fluids always flow from areas of high pressure to low pressure.
Old Feb 17, 2005 | 01:16 PM
Jeff92se's Avatar
I'm needing a caw
Didn't you just say the less pressure the better?
Old Feb 17, 2005 | 01:51 PM
mzmtg's Avatar
Now you're just being silly.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
jaydot901
Sep 29, 2015 01:18 PM
