groaning noise when turning
Old Feb 17, 2005 | 01:48 PM
kenju4u's Avatar
I am hearing a groaning noise when making right turns from the rear right wheel only. No idea what it is but if I had to guess i would say it has to do something with the brakes. Maybe my caliper is sticking or something.
I only hear it for a quick second as soon as I make the turn and then nothing...its kinda of a low level GRRRRRRRRAAH! noise and nothing else.
You guys have any idea what it can be?
-Ken
Old Feb 17, 2005 | 02:05 PM
nismo2ner's Avatar
down with Bing
Half-shaft??? mines doing the same thing cuz it has a cut in it and needs a new boot... but mine also clicks alittle too... so maybe its not ... just my idea
Old Feb 17, 2005 | 04:31 PM
kenju4u's Avatar
yes but this a rear right wheel we are talking about not the front. There is no axle on the rear wheels. Also I noticed that it made that sound when I went over a deep bump very slowly. Its really wired. I guess I cant tell unless I jack up the car and take a look around underneath and turn the wheel.
Old Feb 17, 2005 | 04:39 PM
JetBlackMax83's Avatar
This might be a dumb suggestion you did you check your power steering fluid? I had a low groan from steering and i was a little low on power steering fluid so filled it up to cold and it went away or is the noise coming from the actual wheel well?
Old Feb 17, 2005 | 06:40 PM
nexgenmax's Avatar
R34
I've heard this before to my friend's maxima. What he did, he checked the rubber on his suspension and found that needs to be replaced. Just sharing something hope it'll help. I'm still a noob.
Old Feb 17, 2005 | 07:42 PM
nismo2ner's Avatar
down with Bing
sorry i did not cetch the "rear" part my bad
Old Feb 20, 2005 | 08:55 PM
jguillory's Avatar
Sounds like it could be a strut bearing. Does the sound occur if you're stopped and turn the wheel, or only when you're rolling?
Old Feb 21, 2005 | 10:37 AM
Rotncarcas's Avatar
It only occurs when I am rolling and turn the wheel (ie a 5mph corner) Either direction I believe. I am already shopping for new springs and struts, so probabley strut bearings are in order as well.
Old Feb 22, 2005 | 07:43 AM
kenju4u's Avatar
Well for me it only occurs when making a right turn, in whatever speed...slow or fast it occurs and its almost like something is rubbing on the rotor or wheel, but its only for a sec and then it goes away.
Old Feb 22, 2005 | 12:20 PM
machinehead's Avatar
hub bearing thinger
05RLS2
Sep 27, 2015 09:24 PM
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
LtLeary
Sep 14, 2015 12:33 PM
thenewguyy
Sep 12, 2015 11:12 AM
