What Are The Positive And Neg Wires Of The Window Switches????
Old Feb 17, 2005 | 07:45 PM
G4nismo's Avatar
i recently had my friend order me 50 5mm blue LEDs rated at 4000mcd
and 50 3mm blue LEDs rated at 7000mcd w/ 100 free resistors and free shippin and handlin for $17.50. i wanna use up as most as i can and already have many ideas from seening a billion LEd mod pictures.
i'm planning on doin the climate control, dim and cruise control lights, rear defroster, not the hazard cause i had bad past experiences, window switches,
maybe the led dome light setup, 3 LED illumination behind the center console armrest, last but not least, pockets on the doors led.
i found this thread but don't know is it pertains to my question. it talks about the window switches down below:
1996-1999 Nissan Maxima Security Information
This is the full wire diagram for Maxima everything you need to wire in a alarm
Constant 12V+ White/Red or White/Purple Ignition Switch Harness
Starter Black/Yellow or Black/White Ignition Switch Harness
Ignition Black/White or Black/Red Ignition Switch Harness
Ignition 2 Starter 2 Wire Red/Yellow or Red Ignition Switch Harness
Accessory Blue or White/Blue Ignition Switch Harness
Tach White/Green ECM, Front of Center Console
Neutral Safety Wire Green/Orange Switch on Driver's Side
Brake Switch Red/Green Brake Switch
Trunk Release Purple/Yellow (-) Driver's Kick Panel
Trunk Pin Purple/Yellow (-) Driver's Kick or BCM below Radio
Parking Lights Red/Green (+) Steering Column Harness
Head Lamp Blue/Black R And Gray/Yellow L at Steering Column
Hood Pin Yellow/Black (-) BCM below Radio
Factory Disarm Green/Yellow (-) Double Pulse Will Unlock Doors
Door Trigger Red/White (-) Low in Driver's Kick Panel
Door Lock Light Green/Red(-) Driver's Door
Door Unlock Green/Yellow (-) Double Pulse Unlock
Driver's Lock Brown/White In Driver's Door
Driver's Unlock Brown In Driver's Door
Passenger Unlock Brown In Driver's Door
Horn Wire Green/White (-) Steering Column
Windows Up LF=Blue/RedData Link Switch, Must go to each Switch in each Door
Windows Down LF=Blue/Black
but does anyone know the + and - of the front and rear switches that i can wire my led to?
Old Feb 17, 2005 | 07:57 PM
Crockpot's Avatar
just use a multimeter.. leds for window switches are a direct replacement
Old Feb 17, 2005 | 09:12 PM
G4nismo's Avatar
I Know that. i mean like for when i put leds in the door handles or the pockets, i want them to come on whenever my lights come on. i guess i can guess and check
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
