brighter lights mod dangerous?
Old Feb 19, 2005 | 02:12 AM
dayglo's Avatar
Originally Posted by gepetto
This mod is very simple, but since theres tons of different writeups on it out there, and lots of rumors, it can be confusing. But this is a great way to help your Max look better. Here goes:
Stuff you need: Phillips head screwdriver, flathead screwdriver, nailclippers, electrical tape
1)Remove your clearance light housing. It's pretty simple, just pop the hood and remove the screw that holds it in. With a little bit of tugging, you can pull the side closest to the doors (not the front side) out (it goes behind a little plastic flap). look down into the hood and find the little ball joint socket that holds the clearance light in. take a screwdriver (flathead) and pop it out of that socket. there the light is out.
2)Remove the bulb from the light by twisting it and pulling it out. Place the clearance light housing onto the ground.
3)In your hand you should have the bulb in socket connected to the wires for it. The bulb can be removed from its socket by being twisted and then pulled out. do so now.
4)Look at the bulb closely. On the metal base (below the glass) you can see two metal "nubs." Take fingernail clippers and snip the one CLOSEST TO THE GLASS (the higher one).
5)Cut a strip of electrical tape about 2 inches long and 1/4 inch high. Wrap this tape around the spot where the nub was so that it covers the spot (but not the other nub). This is to ensure a secure connection in the socket.
6)Look down into the socket of the bulb. You can see two notches where the nubs were to be secured (one for the higher nub and one for the lower nub). The bulb, however, now has only one nub (the lower one). Heres the tricky part: you want to put the bulb in so that the lower nub (the remaining one) goes in the spot that the higher nub was supposed to (dont worry if the electrical tape gets pushed a bit).
7) Now that the bulb is back in socket, replace the socket in the housing but dont put the housing back on yet. Flip your lights on to make sure that the job worked (I haven't seen it fail when you use electrical tape). Once your confident that it worked replace the housing (make sure its in there!).
8)Repeat on other side.
Thats it! Took me less than 10 minutes to do!
this sounds realy easy and i wouldnt mind having brighter lights. im assuming this is the headlamp bulbs? or any other bulbs? does it matter?
im not sure if he's talking about corner lights or what...
i want to try but i dont want to fry something, like a fuse, or my bulbs. does this pose any danger or shorten anythings lifespan?
thanks
Old Feb 19, 2005 | 02:26 AM
Bonka's Avatar
Schnell kaputt
Hah first to reply to you again
This is for the corner lamp next to the headlamp.
Read through this and decide if you want to go ahead with it.
http://forums.maxima.org/showthread.php?t=348393
Sounds like the extra heat generated tends to crack the lense. Others haven't had problems. The brighter corner lights do look better though..
Old Feb 19, 2005 | 06:39 AM
makavelisk's Avatar
Yeah this is for the corner lamps. I did that on my 97 max and I had no problems and it made it bright as hell. Looked really good and is really easy to do. Go for it, trust me youll like it. Oh and I never had a problem with cracking or to much heat since that is what a double filament bulb is for.
Old Feb 19, 2005 | 07:26 AM
RockinTheDecks's Avatar
No problems here either...I would like to get new bulbs, however, since I converted the headlights to 9007. Initially, the corners matched nicely, but now the 9007 Silverstars outshine the corners and the difference between the 2 is as if it was stock again. Not to jack the thread, but if anyone happens to give a **** suggestions would be welcome.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
