RPM gauge...DEAD
Old Feb 19, 2005 | 03:36 PM
MaxCanesFan's Avatar
RPM gauge...DEAD
The RPM gauge in my Max will not move. At times it will all of a sudden bounce around, but for the most part it will not do anything, and just sits on zero. The car still runs and idles fine, but the gauge doesn't work. Anyone experienced this before, anything I can do to fix it?
Old Feb 19, 2005 | 03:39 PM
2 Da Max's Avatar
check the connections, my speedometer does that but its because the speed sensor harness is bad
Old Feb 19, 2005 | 04:55 PM
KNYFE's Avatar
It is fairly simple to get back to it. Have to remove a bunch of screws, the steering wheel cover and the whole gauge bezel but I'd bet it is a loose wire. While you are at it you can put in new gauges!!! And lights behind!!! (check my webpage for pics of mine)
Old Feb 19, 2005 | 05:09 PM
guyfromkop's Avatar
same thing happened to me, the only solution is to get new gauges
Old May 14, 2008 | 09:41 PM
nismo98maxima's Avatar
I have the same problem, what did you do it to fix it?
Old May 15, 2008 | 09:10 AM
fat_kid's Avatar
3 year bump ftl
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
slowlifer
Sep 8, 2015 05:53 AM
