Ppl W/ Headers Step In
Old Feb 20, 2005 | 05:18 PM
PTownMax's Avatar
I still miss the max
i'm planning on doing my headers/y/cat either this weekend or next, i was wondering what is the best way to go about getting access to the headers. I also wanted to know if there was anything extra i shoould need for the swap.
here is what i have:
OBX headers/y pipe
New exaust manifold gaskets
Hi flow cat
New cat gaskets/bolts
Header wrap for flex sections
Am i missing anything?
thx.
-Jeff
Old Feb 20, 2005 | 09:27 PM
PTownMax's Avatar
and...bump to da top...
Old Feb 20, 2005 | 09:50 PM
PTownMax's Avatar
how come all the bs threads like intake and y are always answered while the less common questions are just ignored?
Old Feb 20, 2005 | 10:13 PM
goodhead's Avatar
best way to get to the headers is drop the cross membrane support the engine on jack stands, take off the stock y pipe and you should get it out no prob front is a breeze back is a little harder, u joints and extentions are a must. you will need 4 jack stand, and sissor jack from trunk ( to hold engine up) taking off the bolt when exhaust is heated makes it easier, propane torch helps or get the damage bolt remover thingy from sears. there are 5 gaskets. 2x for each header, 2x for headers to y pipe, 1x for y pipe to cat.
Old Feb 20, 2005 | 11:34 PM
XeroX's Avatar
Hella internets
isnt there BIG fitment issues with the OBX headers? like...relocating a motor mount or something? i cant remember...
anyone?
Old Feb 20, 2005 | 11:51 PM
Ceasars Chariot's Avatar
Old Maxima Legend
mreous, and i30tmiked would be some great people to pm about this
Old Feb 21, 2005 | 07:43 AM
|Bijan|'s Avatar
UCF Lexus
free bump for my homie
Old Feb 21, 2005 | 09:03 AM
Zach95SE's Avatar
anyone?
I'm pretty sure you have to cut the motor mount to get the OBX headers to fit. Or I guess you could move it if you really wanted to.
Old Feb 21, 2005 | 09:40 AM
PTownMax's Avatar
yeah had heard about this, i'm pretty sure you only have to cut a little of the mount but i never even thought of relocation... any ideas on where it could be relocated to?
Old Feb 21, 2005 | 10:42 AM
MrEous's Avatar
^ Jeff™
goodhead was right. Best to take off the crossmember. Taking off the intake manifold will give you better access to the EGR valve as well.
Look to spend around 6-8 hours at least...the rear header is the hardest part due to the availability of space (or lack thereof, lol).
Old Feb 21, 2005 | 11:50 AM
96mAx2fast's Avatar
is there a writeup anywhere w/ pics regarding this?
Old Feb 21, 2005 | 12:36 PM
MrEous's Avatar
^ Jeff™
No write-ups that I know of. There are way too many steps that require pics. If you don't understand the basics of how to do it then you really shouldn't attempt it.
No offense.
Take off intake manifold.
Take off crossmember.
Take off stock ypipe and remove o2 sensors.
Take off front header/rear header and anything that bolts to it.
Install in reverse...
lol
Old Feb 21, 2005 | 12:49 PM
5spd99seL's Avatar
The most difficult part for me was removing the rear heat shield, I do not know why but it took forever to remove. So be careful and make sure you have all the bolts off before you start bending and pulling on it. I did not remove the cross member and had no problems with it being in the way.
Old Feb 21, 2005 | 02:00 PM
MrEous's Avatar
^ Jeff™
Just an fyi, I didn't remove the crossmember either but Captain Common Sense says you will be able to get to things better with it removed.
Old Feb 21, 2005 | 02:11 PM
PTownMax's Avatar
don't i need a special socket to remove the o2?
Old Feb 21, 2005 | 02:12 PM
Ant96GLE's Avatar
Yes and no, I'd have luck with an open wrench but there is a special socket thats split so you can put it over the 02 sensor, your better off getting it.
Old Feb 21, 2005 | 02:32 PM
MDeezy's Avatar
sorry for the OT , but I just realized your sig is Bijangxe sig from another angle
Old Feb 21, 2005 | 02:42 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
As far as i know i am the only one with the OBXs installed. It is a nightmare if engine is in the car so good luck lots of cutting of motor mounts also.
Old Feb 21, 2005 | 03:50 PM
Y2KSESteve's Avatar
If I can find my videos I'll post them up tonight. I have one outside the car and one from inside with Cattman headers and cattman cat-back, stock cat...
Old Feb 21, 2005 | 03:56 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
you can use a combo 23 on the o2s. its going to be a pain, i ended up returning mine after sitting looking at it for about an hour. tried doing just the y and it didnt bolt to the stock manis so i called it a day.
their methosd seems to be about right, the manual calls for about 6.5 hours on the rear mani, i was definitely sure it wasnt worth the gains, so i called it a day. if your going to do it i would say that this is a pretty good time to do a write up.
good luck.
Old Feb 21, 2005 | 03:57 PM
|Bijan|'s Avatar
UCF Lexus
hmmm, like the coolant tubing?
Old Feb 21, 2005 | 04:02 PM
maxima_kenny96's Avatar
headers won't do any good pal, on naturally aspirated cars. Just stick with a warpspeed y pipe and high flow cat. yeah! there we go!
Old Feb 21, 2005 | 07:01 PM
MrEous's Avatar
^ Jeff™
...and the gas line too.
Old Feb 21, 2005 | 07:46 PM
Ninos_Maxima's Avatar
be the change u want2C
ahh kenny. show me proof please. Please back up your statement. There was a thread about this a couple months ago.
Old Feb 22, 2005 | 09:30 PM
PTownMax's Avatar
bump for any more info...
Old Feb 23, 2005 | 07:31 AM
96mAx2fast's Avatar
bump
Great thread. More info and some pics if possible would really help us soon to get headers people.. i just got my suspension in the mail last night.. YAY!!!
Complete exhaust is next !!!
Old Feb 24, 2005 | 07:14 AM
PTownMax's Avatar
be forewarned... i'm doing the obx headers but i DO NOT reccomend you go the same route
Old Feb 24, 2005 | 07:25 AM
96mAx2fast's Avatar
why?
Well my brother inlaw does all my work.. he shouldnt have a problem but if anyone has good advice please give it to me.. My brother in law(ronald) has built a Turbo B16 CRX with his bare hands in his back yard.. He also has a 92 Bubble back Civic w/ S2000 Taillights and a custon red/black carbon fiber hood.. Its sick.. he is actually selling the bubble.. he is putting the stock motor back in it as it had a gsr before.. If you are going to do the obx and could possibly take pics , you would be the man !!!
Old Feb 24, 2005 | 08:59 AM
Dave B's Avatar
Not DAVEB the parts guy
It's very true unless you think gaining an additional 3-4hp over the Y-pipe is a significant gain. This has been discussed for well over 1.5 years now.
Old Feb 24, 2005 | 09:11 AM
Old Maxima Legend
dave is right and steve i have a video of your max doing a run with the headers
http://www.ceasarschariot.com/videos.html
Old Feb 24, 2005 | 09:25 AM
PTownMax's Avatar
only one way to find out....
Old Feb 26, 2005 | 04:13 PM
michaelnyden's Avatar
people do headers for the sound on our cars NA....but for the lucky supercharged max's, the increase is insane...somewhere in the neighborhood of 20whp over a aftermarket y pipe...!!!
gigabyte
Jan 6, 2017 06:05 PM
Socalstillen
Sep 26, 2015 12:01 PM
TheMafia
Sep 4, 2015 08:26 AM
