Noise from rear brakes?
Old Feb 21, 2005 | 11:03 AM
Umass021's Avatar
When I am almost at a complete stop I can hear a noise coming from the back of the car but only when I hit the brakes. Do you think my brakes need to be replaced? It isn't loud but you can hear it.
Old Feb 21, 2005 | 11:37 AM
MrEous's Avatar
^ Jeff™
Check for pad wear...
Old Feb 21, 2005 | 11:55 AM
96mAx2fast's Avatar
sound?
Does it sound as if the car was burping or something??!!
I have that problem.. I did my brakes/rotors and everything about 6months ago and when im almost at a complete stop it makes a noise which is alittle deeper than grinding.. i checked the brakes and everything is fine.. its actually just the brakes themselves.. My car stops fine..
Old Feb 22, 2005 | 01:31 AM
Umass021's Avatar
It sounds like grinding but not that loud.
Old Feb 22, 2005 | 02:54 AM
JOMAN's Avatar
well from what i read....the 4th gen max's have unusal brake wear that causes the grindin and in the front brakes, b/c i get that all the time....but its on and off.....so its normal....but like other said...check your brakes and all teh necessary things.
Old Feb 22, 2005 | 06:32 AM
ronin22357's Avatar
i had the same problem and thought it was the rear brakes. but it was really the fronts. i rebuilt the calipers and the noise is gone
Old Feb 22, 2005 | 01:23 PM
Portugalboy's Avatar
Take apart your rear caliper and look on the caliper you should see a steel shim which is part of the brake replacement hardware. If it is loose it will cause the brakes to make noise.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
