Noise When In Reverse
Old Feb 22, 2005 | 08:21 AM
JimmyV12's Avatar
I own a '99 Maxima SE that has recently started making a really unpleasant whining sound when the car is reversing. No noise occurs until the car actually starts moving backwards and does not go away when the brakes are applied. It's quiet at first, then quickly gets louder and the pitch remains constant. My first thought was that it could be a brake wear indicator, but why would it only make the noise in reverse and without applying the brakes?
If anyone can shed some light on what could be causing this, I'd appreciate it.
Thanks in advance for your insights.
Old Feb 22, 2005 | 09:12 AM
Chickan's Avatar
Are you turning the wheel at all while in reverse? Do you notice it at slow speeds or high speeds? Do you notice it at all while going slowly forward in 1st gear? Does the sound go away after you stop moving?
Old Feb 22, 2005 | 09:13 AM
Sin's Avatar
Sin
You're probably just hearing the straight cut gears on the reverse gear.
Old Feb 22, 2005 | 10:48 AM
JimmyV12's Avatar
Sorry - I should have clarified a few things.
The noise is clearly coming from the back of the car, so it isn't anything related to the transmission. It happens only when the car is in reverse and is moving backwards. It sounds like metal against metal, which is what led me to originally believe it to be a brake wear sensor.
I'm at a loss at this point. I haven't reached out to my mechanic, but I'm almost to that point. I'll likely change the rear pads anyway, since they are probably about due for a change.
Old Mar 29, 2008 | 11:00 PM
emanny's Avatar
YEa I get the same noise when I put my car in reverse (5spd) when I start moving it makes like a loud hollow sound my friend said it might be the clutch in reverse is worn but idk anybody can help me out
Old Mar 29, 2008 | 11:25 PM
watut's Avatar
Mine does that too
Old Mar 30, 2008 | 06:18 AM
njmaxseltd's Avatar
Inspect your rear brakes.
Some noise is normal, mine makes the same noise in reverse, so did my BMW.
Worse after it rains or after I wash the car due to residual surface rust on the rotors.
Old Mar 30, 2008 | 08:26 AM
Snypa's Avatar
check the sheild looking things near the rotor area.
Old Mar 30, 2008 | 06:05 PM
HomerMAC's Avatar
Donating i30 Owner
common for these cars to get frozen rear calipers...
Old Mar 30, 2008 | 08:38 PM
mowgli29's Avatar
Horizontally opposed.
word. I gots one. My friend has one too.
Old Mar 30, 2008 | 09:41 PM
VANGtastic97's Avatar
That's exactly what happened to me. I let mine make that screeching sound for three months until they froze up in the winter. I guess it was a warning sign that I didn't take into consideration. sooo...def check your calipers.
Old Apr 2, 2008 | 12:56 PM
hobbes24's Avatar
Dont forget the reverse gear is really small and makes a high pitched noise in any car. If you know what noise im takling about and thats not it then I have no clue, but just an FYI in case.
Old Apr 2, 2008 | 03:07 PM
Joshzap87's Avatar
Hmmm... Mine makes the same noise, but a couple of people I know claim that it is the flywheel. Also, reverse is a really small gear, so it would make a whirring noise. But you say it sounds like metal on metal? Your rear brakes might be touching the rotor. Sometimes there is a little bit of overspray of paint on the side of the actual brake pad when the manufacturer galvanized the metal on the pads.... there might be a little paint chip rubbing on the rotor and that might cause a little metal squeal. If all else fails... either adjust your brakes or check your trans...
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
