95 low RPMs + oil in/on intake manifold
Old Feb 23, 2005 | 09:39 AM
drewmeister_sd's Avatar
My 95 Maxima is acting a bit funny. It is hesitant/lurching/acting like it is starving for fuel or air...both at idle and while driving. I've replaced the PCV valve, but I haven't noticed a difference.
Additionally, I've got a bit of oil which seems to somehow be coming from my intake manifold??? I can't locate any oil leaks where the oil would normally leak out...This car has never leaked any oil and doesn't seem to burn any.
Any ideas on both problems would be appreciated. BTW, it has 152K miles and less than a couple thousand on new NGK plugs.
Old Feb 23, 2005 | 10:05 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
hesisitation - ignition coils, check them out
oil leak - check your coolant make sure you dont have any in your coolant, you may need a new gasket for your intake manifold. might as well replace your head gasket.
Old Feb 23, 2005 | 10:54 AM
DAVE Sz's Avatar
Hooooooonda.....
If you have oil in the intake it's from the hose coming out of the engine and going into the intake. Maybe you put too much oil in during your last oil chnge.
mvm062
Nov 30, 2020 09:00 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
