is my idle too low?
Old Feb 24, 2005 | 06:32 PM
awfulwaffle's Avatar
is my idle too low?
i just got a 97 gxe and i was at a stop light when i felt a weird shutter. i looked at my tach it was idling below one. it was at about 1/2. is that bad? please let me know what might be wrong and what can i do. thanks
Old Feb 24, 2005 | 06:48 PM
Deagle's Avatar
wants the ads to die
Yes, it's low. It should be at about 750 RPMs. You might need to clean your throttle body and Idle Air Control Valve (IACV). Check the stickes on how do them, it's relatively easy.
Speaking of which... I need to do this tomorrow as well. Mine got down to 400 today!
Old Feb 24, 2005 | 07:13 PM
maximazation's Avatar
depends on if hes auto or manual. auto is 750 and manual is lower
Old Feb 24, 2005 | 07:15 PM
2 Da Max's Avatar
clean your tb, its the best mod ive ever done, and ive dumped over 3 gran into the car
Old Feb 24, 2005 | 08:12 PM
maxima_kenny96's Avatar
YES!!! thats bad...I just readjusted mine...I got it idling at about...1,100 now...alittle much I know, but I like the high idle. but yeah...roll it around about...750-900
Old Feb 24, 2005 | 08:44 PM
DragonMaxima's Avatar
Why would you like it?
You're just wasting more gas.
Old Feb 24, 2005 | 08:51 PM
lilaclucymaxima's Avatar
Team Ramrod
yup... just read your owners manual it will have it in there
Old Feb 24, 2005 | 09:37 PM
Deagle's Avatar
Just going off an assumption.
Old Feb 25, 2005 | 02:40 AM
dayglo's Avatar
i like mine high too it feels more smooth. i drive 5spd and mines 650. not high but i dont mind if i have the AC on and its around 8-900.
TB and IACV cleaning made a huge diffrence, and my TB wasnt even dirty atall. so im guessing it was mostly the IACV bieng clean that made the diff. if they wher both dirty i would have shat myself after cleaning them. the improvements are huge
Old Feb 25, 2005 | 03:04 AM
Frank Fontaine's Avatar
I bumped mine up a few years ago and never touched it since. I'm not even sure exactly where it is, but it's also difficult to get down to 50-99 rpm with the tach anyway. Seems like with the Max when the idle is set to spec, if you turn on your high beams and rear defrost, the motor is a touch on the rough side.
But as far as having the idle set really high like over 1000, that does waste fuel. I had a Volvo with Bosch mechanical K-Jet that idled high in the cold--got under 15 mpg in the winter, and around 19-20 in the summer as a result.
Old Feb 25, 2005 | 04:48 AM
njmaxseltd's Avatar
According to the service manual idle speed is as follows:
1995
Manual tranny 550 - 650 RPM's
Auto tranny 600 - 700 RPM's
1996 - 1999
Manual tranny 525 - 625 RPM's
Idle speed specs are with no load (lights heater a/c ect OFF) manual in neutral auto's in D
Old Feb 25, 2005 | 06:03 AM
ziya20's Avatar
How do you adjust your idle, I know one method which is in Hynes manual but that one needs a device to hook up to a cable under the hood.
Is there any other method you gus know, please share.
Thank You
Old Feb 25, 2005 | 06:40 AM
BlackCat's Avatar
RIP '98 Maxima SE
I unplugged the two plugs going to the TPS and managed to adjust the idle but I find it doesn't adjust the idle while engaged in Drive or Reverse. My idle still drops below 750rpm while in either of those 2 positions.
Old Feb 25, 2005 | 07:14 AM
Chickan's Avatar
If you pulled your ecu codes lately, check to make sure you didn't leave the screw at either end, as I've had my idle drop to 400ish forgetting ot move the screw back to the middle.
Old Feb 25, 2005 | 11:09 AM
MaxKlinger's Avatar
Why would you ever want it to idle that high? Unless you're running some sick cams or something, that's not right.
If you have an automatic it's especially not good to idle to high, it's slighly more of a shock and it may cause increased tranny wear over time.
Old Feb 25, 2005 | 04:34 PM
brian96se's Avatar
mine is at 500 in drive. i know that it's low, but the car is running fine. so i'm going to just leave it be.
Old Feb 25, 2005 | 06:18 PM
thanks guys. going to work on it now.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
