H&R or eibach ?
Old May 2, 2001 | 01:49 PM
cRedrum's Avatar
H&R or Eibach ?
Old May 2, 2001 | 02:23 PM
GaMax97GLE's Avatar
do a search
there is ample info out there from a million previous posts.
Old May 2, 2001 | 05:26 PM
dch95's Avatar
Depends....
Originally posted by cRedrum
H&R or Eibach ?
If you are trying to get rid of the 4x4 look but want good ride/driveablity........H&R
If you want performance and don,t mind a little stiffness......Eibach.
Old May 2, 2001 | 06:18 PM
cRedrum's Avatar
Re: Depends....
So you are saying that if you get Eibachs, the car still looks like a 4x4 ?
Old May 2, 2001 | 06:35 PM
dch95's Avatar
Re: Re: Depends....
No. I should have mentioned it earlier. If not mistaken both H&R/Eibach look almost the same (anyone jump in on this one) but the H&R will have the more comfortable ride of the two.
Old May 2, 2001 | 06:38 PM
cRedrum's Avatar
Re: Re: Re: Depends....
Hmm. Now i am in a debate on which to get. Fúck.
Old May 2, 2001 | 06:53 PM
VQ Quick's Avatar
The tokico Eibach set up
rides better over the small stuff than my stock SE set up does. Probably because of the quicker spring rebound. But hit a large pothole and you know. Flipside - cornering is vastly improved. Although I have not riden or driven an H&R setup I can imagine that it is just as good but when pushed hard at the limit it does not have quite the edge that the Eibach set up does. But how often do you drive at the absolute limit. I think I will be inclined to upgrade to the Koni H&R setup.
Makes for a slightly better daily driver and still vastly improves the handling over stock. If I want to totally trick out a car into a racer I think I'll choose a civic or an integra of some sort. But for the max I'll take a little luxury/sport and still have a super sweet ride.
Old May 2, 2001 | 06:58 PM
cRedrum's Avatar
Re: The tokico Eibach set up
Yeah, I KNOW im going for the Konis, and im swinging towards the H&R's too.
Old May 2, 2001 | 08:02 PM
BriGuyMax's Avatar
Actually Tirerack.com did a test of Eibach vs. H&R...and found the H&Rs to be a nose better at the limits..but a little bit more harsh than the Eibachs. Just something to consider....I'm going the H&R, tokico route.
Old May 2, 2001 | 09:33 PM
supertool
How much?
What's the cheapest I can get H&R and Tokikos for?
What's the ride quality vs. stock SE?
Old May 2, 2001 | 10:18 PM
BriGuyMax's Avatar
Re: How much?
try shox.com, they seem to have really good prices...you have to get a quote from them though.
Old May 3, 2001 | 06:34 AM
04 maxse's Avatar
I have had Eibachs before and they were harsher than my H&R's. Although, I think the Eibachs performed a little better. I am one to care about the ride so I like the H&R's better.
Old May 3, 2001 | 06:48 AM
dmbrazilian's Avatar
Ok, what do you guys think of the sprints? Are they just a cheap way to go, or are they good? Please compare to h&r and or eibachs...thanx
late
Old May 3, 2001 | 07:29 AM
ajaffee
Link to Comparison between H&R and Eibach
H&R or Eibach ?
http://www.tirerack.com/suspension/t...bach_hr_rd.htm
Old May 3, 2001 | 10:55 AM
AndyXXL's Avatar
H&Rs and Koni
If you want comfort and performance at the same time then H&R/Koni setup is the best.
Old May 6, 2001 | 11:16 AM
WizzaMax's Avatar
I like my H&R's...the guy I bought from had both and he recommended the H&R's...I have had no complaints so far but will swap struts out probably before the years end.
imported_Nismo_max
Feb 17, 2016 03:39 AM
Peter Paul
Jan 2, 2016 05:18 PM
morteljc
Oct 19, 2015 10:47 AM
95Maxi
35
Sep 2, 2015 10:37 AM
official_style
Aug 29, 2015 10:10 AM
