Still more intake problems....
Old Feb 27, 2005 | 10:07 AM
InsneDrmr's Avatar
So as previously posted numerous times, I installed a CAI on my 98. It set off the check engine light. I went back to stock, and no better. The car recently started having RPM drop offs and was having problems staying on, it kept stalling. Again everything is now stock and its doing this. What could be the problem, and how can I fix it?
Old Feb 27, 2005 | 10:23 AM
maxima_kenny96's Avatar
first off, are u sure u plugged EVERYTHING UP the right way again?
second, if ur stalling maybe u need to readjust ur idle speed.
Old Feb 27, 2005 | 10:33 AM
InsneDrmr's Avatar
Everything is plugged in its all stock again. I just did the self diagnosis i got the codes for Air temp sensor, Knock Sensor, and Mass air flow sensor. What could be wrong with these? And what is a knock sensor?
Old Feb 27, 2005 | 12:10 PM
mansurxk's Avatar
your knock sensor is problaby fine. id check the connections again.
Old Feb 27, 2005 | 12:38 PM
A Flood99's Avatar
you've definitely damaged your MAF or something
first check all connections, disconnect battery, then re-connect battery see if that solves anything..........if not, get a new mass air flow sensor
Old Feb 27, 2005 | 02:31 PM
exit10's Avatar
sry 2 steal the thread but you have SICK lookin rims.
id say its the MAF sensor thats causing u the trouble
Old Feb 27, 2005 | 02:34 PM
A Flood99's Avatar
thanks bro, i couldn't have been happier how they fit in with the car
Old Feb 27, 2005 | 03:16 PM
Torgus's Avatar
it's obviously his maf.
he probably didn't plug it in. <----
or somehow he managed to damage it....which is hard to do...
i never knew there was a code for the temp sensor. unless you BROKE IT off.
Knock Sensor: goto any mechanic and they'll fix it. Y
No Offence...but you don't sound like a hands on guy.
also i'd just like to say that an intake is the most simple thing you can do. if you can't install this don't mess with your car ever again. no oil changes. nothing.
good luck.
Old Feb 28, 2005 | 10:24 AM
InsneDrmr's Avatar
I did that self diagnosis thing, it gave me the code for the mass air flow sensor, but after resetting the check engine light like you are suppossed to the car runs great again. Could it be I just had to reset that?
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
