Mass Air Flow Sensor Problem
So....its seems my MAF isnt working properly, I may need a replacement. How much do those go for?....and where could I locate one? Junkyard maybe? Suggestions please!!
I did that self diagnosis thing, it gave me the code for the mass air flow sensor, but after resetting the check engine light like you are suppossed to the car runs great again. Could it be I just had to reset that?
if resetting your ecu fixed the problem, you may be fine. Just monitor it. As for a replacement, www.twinturbo.net has an excellent classifieds section.
Do not buy one from the dealer. Go to www.car-parts.com, they will have many many to choose from
If your MAF is truely bad you won't be able to drive the car. If you got a MAF code and reset the ECU and the code has not come back then I would not worry about it for the moment
It will be driveable, but ony in "limp mode" That is by disconnecting the MAF, you will only get to 2.5k max, but it will get you where you need to get if it's not terribly far. I bought one off of www.car-part.com for $45 shipeed, been on since 8/04, works nicely.
Originally Posted by InsneDrmr
i went and did the self diagnosis thing again, 3rd or 4th time now...knock sensor came up as the only problem, how can I go about repairing/replacing this?
Do not worry about the knock sensor right now. Worry about the MAF, knock sensor can wait and is not going to cause you any driveability problems
bc992164
Aug 26, 2015 12:19 PM
doobadoo
Aug 15, 2015 06:43 PM
