pulled some codes... need help on identifying one of them..
Old Feb 28, 2005 | 11:10 AM
ShRapNeR's Avatar
cel came on.. thought it might have been the drop resistor mod i did so i ignored it..
well got to wondering. so i had the codes ran..
pulled a P0325 and P1445
guy told me the P0325 is one of the knock sensors on my car. and thats why my car is hard to crank at times...
and the P1445 is something nissan would have to look into.. said it was emmisions control system or something..
anyone know what exactly the P1445 is and what i would need to fix it.. and is changing a knock sensor a DIY job or should i have a shop do it..
if its just 1 of the KS.. think its best to change both all at the same time?
Old Feb 28, 2005 | 11:16 AM
Akumachan's Avatar
I never narc'd on nobody.
did you get these codes with a scna tool of some kind, or did you do a self diagonsis with the screw on the side of the ecu? i only ask because neither of the codes you have there really exist... so either learn how to count, or gie the right codes. also, since when does the VQ30 have more than one knock sensor?
Old Feb 28, 2005 | 11:18 AM
ShRapNeR's Avatar
odb2 scanner at autozone.
MDeezy's Avatar
0304 is Knock sesnor.
I shouldnt know that off the top of my head
ShRapNeR's Avatar
yea.. there is a P in front of them
*EDIT* is there any way to tell which knock sensor it is?
Old Feb 28, 2005 | 11:19 AM
MDeezy's Avatar
ohh that changes everything.
we only have one knock sensor.
(thank god . . . )
Old Feb 28, 2005 | 11:22 AM
0325 scan tool=0304 ECU code .......... same thing knock sensor
Open up any Hayne's and you see the chart listing what code you get depending on the method of code retrieval.
Your knock sensor is fairly easy to replace, assuming you have the right tools and someone with small wrists. Otherwise, the intake manifold needs to come off. All in all, it's definately a DIY job.
Hope that helps.
James
ShRapNeR's Avatar
(thank god . . . )
where is it located?
Old Feb 28, 2005 | 11:23 AM
ShRapNeR's Avatar
Hope that helps.
James
i bet if i took it to the stealership they would take the manifold off and charge me more. lol
Old Feb 28, 2005 | 11:26 AM
MDeezy's Avatar
you know they would so that they can spend more time on your car and cost you more money.
a 12" socket extension and universal swivel attachment got a KS out in 2min flat. and saved my big ass wrists from being cut the Fuck up!
Old Feb 28, 2005 | 11:41 AM
Akumachan's Avatar
P1445 = 1008 = EVAP canister purge volume control valve, and i have no idea what where or how, but that'll get you started.
Old Feb 28, 2005 | 11:45 AM
What about undoing the "drop resistor mod", resetting your ECU AND erasing the memory of ECU using the scan tool, and monitor to see if your codes come back?
James
Old Feb 28, 2005 | 12:03 PM
ShRapNeR's Avatar
James
im going too...
im thinking thats whats throwing the evap code..
but im gonna see about changing the ks myself..
seems like this time last year i had my evap worked on so who knows
D Mason
Jun 21, 2016 04:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
