don't know what's wrong?
Old Feb 28, 2005 | 12:00 PM
99maxGTR's Avatar
so it started with the shaky idle between 500-700 and now i noticed that when i turn my headlights on the light for the odometer turns off and also the lights for the windows, clock etc and shifter are much dimmer. the wierd thing is that when off my healights the light for the odometer turns back on.
im a so please help me out.
Old Feb 28, 2005 | 12:11 PM
brad kay
i dont know about the lights and stuff.. but the idle check you're idle air control valve
Old Feb 28, 2005 | 12:20 PM
dayglo's Avatar
there was a post a bit ago about alternators going bad, peoples interior controls going kindof haywire, sounds kindof like this
when u rev does everything brighten up?
: o
Old Feb 28, 2005 | 12:26 PM
Kazao's Avatar
I dont know what that is but it could be alot of things. It could even mean your battery is going bad, or your altenator, or the distributor, or even the grounding kit.
Old Feb 28, 2005 | 12:30 PM
BlueC's Avatar
wat
I hope you're kidding...
Old Feb 28, 2005 | 12:42 PM
tavarish's Avatar
fwd gone rwd cr00
hehe....someone's been working on hondas...
just for the people that don't know...
Maximas are distributorless....they instead have COIL PACKS
Old Feb 28, 2005 | 12:43 PM
Akumachan's Avatar
I never narc'd on nobody.
clean youre throttle body and read the stickies!! and yeah, im kidding... i just thought thats what the old guys would say...
Old Feb 28, 2005 | 01:19 PM
2 Da Max's Avatar
just keeping reving your engine and it will be like normal again
Old Feb 28, 2005 | 01:58 PM
maxima_kenny96's Avatar
LOL...the good ol' days when cleaning ur throttle body would add an extra 5000hp according to the maxima vets.
Old Mar 1, 2005 | 07:16 AM
99maxGTR's Avatar
2 da max...im getting tired of that...thanks every for the info. i have cleaned my throttle body before and that kind of helped but ive been hearing alot about the IAC valve so im going to get that cleaned next...but as the electrical problem maybe i'll learn to live with it? :T
Old Mar 1, 2005 | 07:19 AM
2 Da Max's Avatar
yes clean the iac valve if you didnt do so already. but it sounds more of an altenator problem. take your car to autozone or pepboys and see how many amps your altneantor is putting out. but this shakiness goes away after a minute of 2 of driving right? do you hear like a whining noise at startup? you have a 99 so your big 3 should be fine
Old Mar 1, 2005 | 08:07 AM
PAREDLINE's Avatar
For the electrical problem.
First check all of your fuses. With a circuit tester.
Make sure your DIMMER switch is on the brightest setting. Its located on your dash just under your instrument cluster next to the fuel door switch.
You might need to replace this. Try to find a friend with the same car and borrow his switch.
You might need a new headlight switch-stalk. This is a pain in the ***.
I think your dimmer switch is on dim. Thats the first thing that comes to mind.
You said it started with shaky idle. It sounds like two different problems. Is the shaky idle still there? You might need a good throttle body cleaning, air filter, and tune up. Especially if the check engine light is not on. IAC valve would make the CEL light go bright unless I am mistaken.
Peace
DayHeyZeus
Sep 11, 2015 03:17 PM
220k+ A32
Sep 11, 2015 02:18 AM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
